Eaton Superchargers?
Oct 21, 2008 | 08:40 PM
Does it matter which way up they are mounted, (Eaton m45 off a cooper S) or does it have to be a particular way for the oil in the gears?
Oct 21, 2008 | 08:52 PM
Oct 21, 2008 | 10:42 PM
Seen them fitted different ways up. Think they are ment to have the oil fill hole horizontal or at least it can be filled.
Oct 22, 2008 | 10:57 AM
They are factory filled for life...
Oct 22, 2008 | 07:30 PM
Oil is on ebay and its worth changing
Oct 22, 2008 | 09:43 PM
According to Eaton they can be positioned anyway you like, even vertical
Oct 22, 2008 | 10:02 PM
No manufacture recomends you change the oil...
I've seen 150k mini cooper S with the original charger - so what you basing the idea that oil change on? Just cos its on ebay?
Oct 23, 2008 | 09:25 AM
If you belive the oil will 150k and still be a lubricant free from impurities then fair do's. I guess you don't change your gear box oil either.
Oct 23, 2008 | 10:29 AM
Quote:
Originally Posted by
robrs2
Not unless it says to - I work on the theory that the manufacturer is smarter than I am.
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
markk
Sep 9, 2015 08:11 AM
foreigneRS
Sep 8, 2005 12:05 PM
percybigun
28
Jun 21, 2005 04:17 PM
Rich@rd
15
Jul 15, 2004 09:26 PM
