4x4 rs turbo
a friend of mine wants to convert his s2 turbo in 4x4 can he use a 4x4 cossie gearbox?
he wants to use a zetec block so would he have to get a bell housing mad up if so where would he get one
seems a stupid arse way of doing it to me, may as well go full cossie including yb if your converting the floor plan to 4x4 Just buy an old saff with a rotten shell and use that for the conversion
Although you could use the RS2000 4x4 setup which I know has been done a couple of times.
The bell housing is the last of his problems, custom engine mounts, exhaust, pipework, to name but a few
Hope your mate has deep pockets, doubt he would get any change out of 10k if he did it on the cheap
he's already got a floor pan ready to go in and his shell has been cut, il tell him anyway.
basically hes going for a big power zetec turbo but he wants to know if you can fit a 4x4 gearbox to a zetec block. ive already told him go for cossie but he said its been done
I think the reason the cossie has been been done is that it works, I fail to see what your mate will gain other than problems, with having to make engine mounts etc
does anyone mind the white FRST in Fast Ford a few years ago? It was running a 2.1 zvh and 4wd, think it was mondeo running gear in it but it was supposed to be about 250 bhp?
big_Rad
Sep 15, 2017 09:36 AM
Matt Baxter
Sep 16, 2015 08:30 PM
