testing the water...what do you think its worth
All this stuff apart from the rocker cover and head casing is brand new and never used.
Genuine Cosworth forged low comp pistons (std size)
Arrow H beam Forged con rods with arp bolts
Brand new yb cosworth block (not a shitty 99 cast block either)
Pair of BD16 cams
Pair kent verner pullyes
Water pump, aux and bottom pullys freshly powder coated white
Fully ballanced crank
Lightend & faced flywheel
Ported and polished head with kent double valve springs
Standard inlet with ported and polished elbow
rocker cover with all the paint stripped off.
thanks
mike
Pair of BD16 cams
thanks
mike
think they are for a 2wd head but have adapter for a 4wd head, or vica versa,
they have been bolted into the head but never run.
not sure on price, i want to see what everything together is worth before i decide to sell or not.
