Cossi Brake bleeding problems
Old Oct 17, 2008 | 04:51 PM
mustang 390's Avatar
mustang 390
Default Cossi Brake bleeding problems
How do you bleed a complete system got no pressure to the rear. Has any one doctored a cosworth abs system to fit an old ford, ie:- useing the elc/pump/ master cylinder /acumilator. but leaving out the distribution valve block and abs module.. if so any info will be greatfully recieved.
Old Oct 17, 2008 | 05:01 PM
Kverna's Avatar
Kverna
Virgin-popper
Extremely basic, but start on the wheel furthest from the tank, and go:
Left rear wheel, right rear wheel, left front wheel, right front wheel. Repeat untill only fluid pumps through, and remember to refill the tank
Old Oct 17, 2008 | 05:07 PM
mustang 390
Tried that, nothing. pedal hard and undone bleed nipple on rear and pedal still did not travel any further and no fluid passing through.
Old Oct 17, 2008 | 05:17 PM
robbieg's Avatar
robbieg
Have you tried it with the ignition on(when bleeding the rears)??
Old Oct 17, 2008 | 05:39 PM
mustang 390
Yes , no difference. I must explain that this is fitted to an anglia so have only plumbed in the master cylinder, not valve block or abs, with the 2 outer ports on master going to the front and the centre outlet going to rear. hope this is correct.
Old Oct 17, 2008 | 05:51 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
you have to bleed the rear brakes with the engine running.
Old Oct 17, 2008 | 06:45 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
easy, just rip all of that crap out and fit a servo and master cylinder... worked on my cossie
Old Oct 17, 2008 | 08:25 PM
mustang 390
Don't you lose servo assisted brakeing when you come on boost due to inlet manifold produceing positive pressure instead of vacuum ?
Old Oct 18, 2008 | 06:11 PM
Char1ie's Avatar
Char1ie
I had the the symptoms you describe - no pressure or fluid to the back. I found that my servo failed. Disconnect the middle connection coming out of the servo and see if fluid sprays out when you press the pedal. The middle connection is for the back. Mine was seized and I had to fit a replacement servo - only 20 quid in the end.
Charlie
Old Oct 18, 2008 | 10:56 PM
mustang 390
Charlie
Thanks for that, when you mean replaced servo ,did you mean you replaced the master cylinder, or the valve block on nearside engine bay.
Old Oct 21, 2008 | 09:37 AM
Char1ie's Avatar
Char1ie
It is the master cylinder assembly - back left of engine bay as you look from the front of the car - just behind the turbo heatshield. Brake pedal is attached to it. You'll see it has three outputs under the reservoir. Front and back outlet are front left and front right brakes. Middle output is for the back brakes. Disconnect the middle and press the brake pedal. If fluid doesn't spurt out you have a dead master cylinder. Get a replacement. If you have a 4X4 I have a spare you're welcome to. Mine is 2WD.
Charlie
original
Apr 28, 2026 05:20 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
Red_bull
Aug 9, 2015 08:34 AM
