rst1 wont start!
Old Oct 15, 2008 | 11:18 AM
xr_triplow_turbo's Avatar
xr_triplow_turbo
Default rst1 wont start!
hello peeps i have a series one rs turbo that wont start it has been left in my garage for 6months, it was running perfect, but now there is no spark, there is power at the coil but doesnt seem to have earth there ive cleaned up the battery earth that mounts to the shell.
could it be a relay etc????????????????????????? thanks.
Old Oct 15, 2008 | 11:40 AM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
difficult to tell with out seeing it.
First thoughts are poor earth or the ignition relay
its under the dash on the drivers side, a small metal silver box, these are well known for playing up!
sometimes mine used to play up and a wiggle of it would sometime be enough to start it.
they are about Ł80 for a new one.
also how good its the battery, do you have a mulitmeter, if the current drops below about 9v when cranking then you probably wont get a spark!
as said with out seeing it cant ofer any more help
Old Oct 15, 2008 | 11:52 AM
xr_triplow_turbo
battery is good, is the ignition relay same as the one in an xr3i?
Old Oct 15, 2008 | 12:55 PM
jammy86's Avatar
jammy86
Is it possible to bypass the IGN relay to test if it is this that is the problem?
JAmes
Old Oct 16, 2008 | 09:56 AM
Cozziekid's Avatar
Cozziekid
The ignition amplifier on the distributor is a common problem.
Old Oct 16, 2008 | 03:23 PM
xr_triplow_turbo
well lads it seems to be just that yellow relay by the ecu, its running but the fuel pump wont stay on. anyone no which relay controls the pump and where it is?
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
