focus headlight bulbs blowin
Old Oct 14, 2008 | 01:11 PM
towncruiser's Avatar
towncruiser
Default focus headlight bulbs blowin
hi just wounderd if any one could help
i have a focus 1.6 petrol zetec and im for ever puttin bulbs in it
iv tryed changin 2 . they seem to last a bit longer. but still not as long as they should
has any one els had the same problem ?
any help would be gr8
Old Oct 14, 2008 | 01:52 PM
iansoutham's Avatar
iansoutham
OCD Victim
Sounds like the alternator is over-charging.
Old Oct 14, 2008 | 03:49 PM
Is the filament breaking or are they going black ?
Old Oct 14, 2008 | 04:10 PM
towncruiser
you think ?
if i dont put a new one in the one that workin now will last for ever and a day
but soon as i replace the the faulty one the other will go
Old Oct 14, 2008 | 04:12 PM
towncruiser
i think the filament is breakin but i cant really remember
Old Oct 14, 2008 | 06:11 PM
If the bulbs are going black it is usually down to a bad earth, but if broken because of overcharging it would not just blow these.
How much life are you getting ?, ever thought about HID.
Old Oct 14, 2008 | 07:10 PM
towncruiser
im gettin about 2 weeks max out of them
have thought about HIDs but they aint cheap so i dun wana be forking out for them if they not goin 2 last either
Old Oct 15, 2008 | 07:00 AM
2 weeks, something is defo wrong, as it is both bulbs the most likely is the current, even if ok when measured it could be spiking, on this car it will almost certainly be ecu controlled so a not so inexpensisive cure if that.
Old Oct 16, 2008 | 01:53 PM
towncruiser
i herd sum where its comon on sum fog light models
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
TPM961
Jan 15, 2018 10:50 AM
Tank Mike
Ford Focus ST Parts for Sale
May 18, 2016 09:38 PM
Kam B
Sep 24, 2015 10:40 AM
Flatlinedan
Sep 18, 2015 12:41 PM
