Replacing Ecu on RST S2
Old Oct 13, 2008 | 10:49 PM
anvini's Avatar
anvini
Default Replacing Ecu on RST S2
Hi
I found a chipped Ecu to replace my standard BLUE-RED-BLACK Ecu.
The problem is that the chipped ecu is HEARTS & DIAMOND Type.
Can I fit the ecu on my RST s2?
Will have running problems with this Ecu??
Thanks
Old Oct 13, 2008 | 11:24 PM
Red_bull's Avatar
Red_bull
won't be a problem mate,
The diamond and hearts ECU has more features like the knocksensor. When it's not on your car is won't be used and it won't be a problem. Running will be the same as your old ECU unless you are going to change your boost, then it needs to be set up again
Old Oct 13, 2008 | 11:44 PM
anvini's Avatar
anvini
Hi mate!!
Ok!!, so no problem, Ecus are compatible??
My car have knock sensor so standard ecu have knocksensor control.
CheeRS
Old Oct 14, 2008 | 10:29 AM
RSTurboSI's Avatar
RSTurboSI
as red bull said mate.
Just will need a re-set up.. jobs a good un
Old Oct 14, 2008 | 02:00 PM
anvini's Avatar
anvini
Re-set up, it is a fuel & boost preasure adjustment on rolling road??
JK12
33
Apr 26, 2021 12:09 PM
`spotty
Sep 25, 2015 11:41 PM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Billy_RS
Sep 13, 2015 04:17 PM
