pinto with cosworth brakes spongy help ?
Old Oct 13, 2008 | 07:41 PM
tank1987's Avatar
tank1987
Default pinto with cosworth brakes spongy help ?
hi all you've never failed with the helpful advice in the past so i need to ask some more .
as you know i got a 3dr cossie replica runing pinto turbo with standard pinto master cylinder and servo and 2wd cosworth calipers front and brake but brakes are very spongy, can anyone help.
Old Oct 14, 2008 | 07:53 AM
If you haven't already put on braided lines all round, get the single piece front ones and secure to the strut body, then just make sure calipers are nice and free no sticky pistons, also make sure handbrake(if on DRUM rear?) is adjusted up as most lost movement comes from here, then just bleed as normal.
I had this set up on a few sierras only noticed a very slight increase in travel, but no spongyness, otherwise look at seals on m/cyl.
Old Oct 14, 2008 | 09:46 AM
tank1987's Avatar
tank1987
yeah i got reconned calipers all roung and braided pipe disc on back not drum they do work just ALOT of travel
Old Oct 14, 2008 | 05:24 PM
Thefuturesbright's Avatar
Thefuturesbright
JAFSPORT
Prob need rebleeding.
Old Oct 14, 2008 | 07:17 PM
tank1987's Avatar
tank1987
bleed a load of times
Old Oct 15, 2008 | 05:32 PM
studabear's Avatar
studabear
when u fitted the calipers did u put them on the correct sides so that the bleed nipples are at the top?
if this is correct and ur still on normal flexi hoses clamp the all up with properbrake hose clamps if the pedal is then solid, remove them 1 at a time checking the pedal pressure, as soon as u remove 1 and the pedal pressure goes bad again thats the corner ur fault is at
If you can't get good pressure with all 4 hoses clamped then theres a fair chance your master cylinder is goosed
Old Oct 16, 2008 | 05:52 PM
tank1987's Avatar
tank1987
does anyone have info on running abs pump without using the abs system
Old Oct 18, 2008 | 08:30 AM
ewanm3's Avatar
ewanm3
hi mate i am also looking for some help on the cosworth brakes how did you get the presure swith and main valve wired up thanks
Old Oct 18, 2008 | 01:02 PM
tank1987's Avatar
tank1987
thats what im try to work out mate as soon as i work all out ill let you know
Old Oct 18, 2008 | 06:55 PM
ewanm3's Avatar
ewanm3
thanks alot mate
Old Oct 25, 2008 | 05:31 PM
ewanm3's Avatar
ewanm3
i have now found a full wiring diagram but dose not seem to help much
Old Oct 26, 2008 | 01:33 PM
tank1987's Avatar
tank1987
please could you email me the diagram dicky_roberts@hotmail.com
Old Oct 26, 2008 | 09:11 PM
ewanm3's Avatar
ewanm3
my friend has it mate i will try and get it tomoro and mail it to you
Old Oct 29, 2008 | 10:20 PM
ewanm3's Avatar
ewanm3
ok mate i have sent it let me know if you get it ok and if you can work out what needs to be done thanks
original
Apr 28, 2026 05:20 PM
big_Rad
Sep 15, 2017 09:36 AM
Ben26
Aug 27, 2015 08:56 PM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 6, 2015 07:40 PM
