cts stage 2+
Oct 13, 2008 | 01:36 PM
cts stage 2+
how much torque will it take
thanks
Oct 13, 2008 | 01:59 PM
if u phone them they'll tell u cts-01582840008.
Oct 13, 2008 | 04:57 PM
already phoned he said it should take 260+ ft/lb i'm not so sure. does shot peening make that much difference
Oct 13, 2008 | 05:01 PM
So the guy who builds them gave you a figure, and then you came on here to ask?
Oct 13, 2008 | 06:15 PM
they will hold more though=) just look around and see what some of the guys running it on
Oct 13, 2008 | 08:03 PM
id say mine is around 300 an its still holding out
most of the fastest rst around run them olli and tim nms cars also run them.
Oct 13, 2008 | 10:29 PM
i would say that 260lb/ft will be a bit of an understatement tbh! a standard one will take 230 lb/ft if treated correctly with no hard launches!!!
Oct 13, 2008 | 10:58 PM
i've already got a stage 2 just wondered how much stronger 2+ was or to go with a quaife straight cut
Oct 13, 2008 | 11:25 PM
what do these gearboxes cost new? and what prices do they go for second hand if they are available?
Oct 14, 2008 | 08:02 AM
Quote:
Originally Posted by
Red_bull
about Ł 800
Oct 14, 2008 | 02:02 PM
i have one in my fiesta and its running just over 300 lbs, but mine bloody broke, part of the lay shaft and the pinion is broken, waiting to see wat happens, my gear box is at cts at the min, its going to cost me over Ł800 to fix, my box is the stage 2+.
so really, i dont think it can take 300 lbs with huge abuse but having said that my car used to run 341lbs and it did not break then.
i think its down to the way you drive it if you just plant it and dont take your foot off the gass wen its in gear you should be ok, thats wen mine broke, wen i took my foot off the gass
Oct 14, 2008 | 03:52 PM
i broke every tooth off 2nd gear and the input shaft, think i'm going with a quaife straight cut kit
JK12
33
Apr 26, 2021 12:09 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
