escort gti overheating
Old Oct 12, 2008 | 08:05 PM
turbo_j's Avatar
turbo_j
Default escort gti overheating
my escort gti is over heatingwhat the first thing to try? doesnt seem like the fan kicks in, could it be that? does any one have any suggestions is this a normal zetec problem? any help would be amazing
Old Oct 12, 2008 | 09:42 PM
Cozziekid's Avatar
Cozziekid
If the fan isnt cutting in its either the fan itself or the thermo switch. Take the plug off your thermo switch and bridge the terminals in the plug with a piece of wire (the ignition needs to be turned on), if the fan kicks in its the switch, if it doesnt its the fan itself at fault or a fault in the wiring. Also check your fuses.
Old Oct 13, 2008 | 03:26 AM
Unplug the ECU temp sensor and the fans will just run if they are working as this is a default state for the ecu when no signal is returned for ecu.
Zetecs do not have any major overheating problems really.
Old Oct 13, 2008 | 07:23 PM
turbo_j's Avatar
turbo_j
Thanks for the replys i will defo check them out this weekend my mate had a gti for a while and said his always ran at 3/4 but never boiled over mine hasnt boiled yet but dont want to risk it.
Old Oct 13, 2008 | 08:21 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
My fan packed in on my Si, it was the relay which is located behind the battery. Bloody expensive too.
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
