focus rs conversion
i have a 51 plate ford fiesta, and iam thinking of changing my 1.25 with a focus rs engine, does anyone know of anyone that has done this, would it be hard to do,
any info appreciated
thanks regards ashley
i have just finished building a frs engines 1.6 focus with a mate. we built it fro someone on here. but no idea about fiesta.
i would expcet the areas your gonna need to look at will be
driveshafts
engine mounts
steering rack/exhaust
ecu etc
is a 125 engine inlet at the front or back of the block?
driveshafts
engine mounts
ecu etc
i'm doing it at mo cus of ure engine if ure not gonna run the rs box u need to swap the bellhousing round i've used the fiesta 1800 diesel if u run the rs box u need to make a box mount and cut out some of the chassis leg to fit i.e harder engine mount is a piece of piss to make took bout a day to make ull need custom drive shafts other than that its just plumbing and fiddling round with other stuff
p.s if u use ure box after speaking to cts i think ull need atleast a s2+
liamT74
Sep 23, 2015 10:24 PM
