project zetec turbo build
Old Oct 9, 2008 | 07:47 AM
performace_ford's Avatar
performace_ford
Nae Bither!
Default project zetec turbo build
can anyone help??????
i have a mk3 escort and am wanting to build a 2.0 16v zetec turbo to put in it
i know i have to blank of the breather at the front of the engine but where will the re-placement 1 be?
managament??
cheers
Old Oct 9, 2008 | 07:48 AM
Luca's Avatar
Luca
Lukesville
If you can help it dont block the front breather keep it.
Old Oct 9, 2008 | 07:51 AM
performace_ford
Nae Bither!
Smile
cheers for the reply
i heard u have to change it because of clearence for the exhaust but i have a tubular manifold so this might resolve the problem
any more infor mation on a zetec turbo build would be great??
Old Oct 9, 2008 | 09:07 AM
JesseT's Avatar
JesseT
Yes, it might resolve the issue. I kept mine at the original position too.
The biggest pain in the **** was the engine mount. It's not the same on a mk3 as on a mk4 and it's hard to make the mounting rubber clear the oil pump/filter. Early 80-83 Escort CVH engine mounting rubber will work but they are hard to find as new.
Old Oct 9, 2008 | 10:30 AM
performace_ford
Nae Bither!
cheers well i have already put a 2.0 zetec into it so the engine mount has already been done so i havent that to worry about anymore
Old Oct 9, 2008 | 10:35 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You need to decide what exactly it is you want to do, as some stuff will be a problem and some wont (eg, front breather is ok with a focus rs manifold setup)..
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
