bigger rear disk and master cylinder options for mk6 escort.
ive got a mk6 escort with 30mm front brakes and an RS2k rear beam with 270mm (?) disks, but im looking for something slightly bigger at the back to fill up my rear wheels. what else fits?
in running brakes this size should i be looking for an alternative master clylinder as opposed to the standard one? again, what options have i got?
cheers.
cheers.
Does the RS2K have an integral drum / disc braked rear ?
If your not changing calipers then no change is needed to the m/c
Try posting in the escort or technical rooms
Red_bull
Aug 9, 2015 08:34 AM
