Escos heated front windscreen??
Old Oct 7, 2008 | 12:23 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
Default Escos heated front windscreen??
Hi guys, going to try and bin the heater box out of my track build, can you fit a heated front screen to an escos? did they come std or did any of the mk5 escorts come with them??
Any info much appreciated.
Dan
Old Oct 7, 2008 | 12:54 PM
MarkN's Avatar
MarkN
Luxes came with a heated front screen. I think all Mk5/6 Escort heated screens are the same so should go straight in...
Old Oct 7, 2008 | 01:13 PM
KSA-Cossie's Avatar
KSA-Cossie
As above.
Old Oct 7, 2008 | 01:15 PM
JHS's Avatar
JHS
Mine has a heated screen, but no switch for it anywhere though
Old Oct 7, 2008 | 01:41 PM
booner999's Avatar
booner999
if no luck here try escortrscosworth.com
Old Oct 7, 2008 | 07:29 PM
Kelv's Avatar
Kelv
Almost there!
As said above Dan, some did come with heated screens.
i looked into getting rid of my heater box aswell, then Martoon went and weighed one, even with the matrix section full with water it only came to 4kilo's
- is a slight bit of warmth and the fact that it actually drys out moisture etc really worth sacrificing for that little bit in weight?
Old Oct 7, 2008 | 07:49 PM
SillyFezzaMk1
Rubber Rhino Crew
get what your saying but I really can't be arsed with the heaterbox and pipework as my dash no longer has vents or an area for the controls. I might try and get a tiny heater/blower from work that go in the tiny diggers we build....that'll be enough to keep me warm, and even then it's a good weather car anyhow so should only need the heater on the way to nurburgring (sp) or similar overnight drives.
Dan
Bailes1992
Sep 3, 2015 02:17 PM
james kiely
Aug 28, 2015 08:58 PM
borboyous
Aug 22, 2015 11:17 AM
C2 MAK
Aug 20, 2015 09:46 PM
track.focus'd
Aug 12, 2015 05:53 PM
