flushing
Old Nov 11, 2004 | 06:08 PM
gus's Avatar
gus
Default flushing
whats the best stuff to use to flush a engine?
i just brought a old smoker to run about in and the head gasket has gone at some point, leaning a bit of gunk behind
thanks oin advace
Old Nov 11, 2004 | 06:10 PM
luke eversham's Avatar
luke eversham
i always use forte, good stuff but dont put it in a cvh,
Old Nov 11, 2004 | 06:11 PM
AJ Escos's Avatar
AJ Escos
diesel, drop some oil add diesel run for 5 mins then drain job done
Old Nov 11, 2004 | 06:24 PM
gus's Avatar
gus
thanks lads will give the diesel one a go then, just gotta nick some more from work now then
Old Nov 11, 2004 | 06:29 PM
SteveB's Avatar
SteveB
Comma do a engine flush in a green can you drain all the old stuff out and replace with the correct amount of the flushing oil, run for XXX amount of minutes then do an oil and filter change as normal
AJ Escos's Avatar
AJ Escos
should work a treat m8, but do NOT use petrol instead like someone i know his answer,well its fuel isnt that what you meant idiot didnt know diesel is oil based and petrol isnt he even said it was noisy when running
Old Nov 11, 2004 | 06:30 PM
gus's Avatar
gus
MadMac
Jun 30, 2005 04:22 PM
Andy f
Jan 24, 2005 07:47 PM
Chipperx2
Sep 3, 2004 07:51 PM
landynutter
Aug 16, 2004 01:42 AM
yanrs
Jan 6, 2004 02:57 PM
