cossie running problems
Old Oct 5, 2008 | 09:43 AM
worm's Avatar
worm
Question cossie running problems
hi all i have a 2wd sapphire the problem is that it has an idle problem and has a splutter when you are at a constant speed it doen't hunt when idleing its poping out the exhaust and feels like it wants to cut out but then fine again for a second if the ambient air tempreture sensor is unplugged it runs like a swiss watch the fueling has been checked through the rev range and is fine it its got a new at sensor wt sensor and crank sensor but made no diference plugs cap and rotor are also new
Old Oct 5, 2008 | 04:09 PM
You have afuelling issue as the only thing that the air temp sensor does is apply a TINY correction to the fuel map.
I would check the basics like rail pressure first.
Old Oct 5, 2008 | 07:02 PM
Dave Henshall's Avatar
Dave Henshall
and i bet your are running champion c57 plugs....?
if so - get rid - they are cheap but cause all sorts of lumpy arse idle issues in my experience. if its running std boost then the best plugs for it that will make a huge difference to the smoothness of the idle are the small turbo esocs platinum ones motorcraft no AGPR12PP8.
Old Oct 6, 2008 | 04:34 AM
stevecossy's Avatar
stevecossy
Im running C57 plugs and never ad a prob with em on road or track, so guess its maybe same as -71s some good and some not so.
Old Oct 6, 2008 | 05:34 AM
It's worth swapping the plugs in case they are super sensitive to the mix, as aid I would use AGPR12PP8, ace plug up to around 300bhp, after that IK31.
Old Oct 6, 2008 | 01:07 PM
worm's Avatar
worm
thankyou for you ideas its going to get looked at tomorrow so hopefully i can get it sorted
Old Oct 18, 2008 | 02:58 PM
Dave Henshall
any news back ?
Karl 3dr
102
Oct 14, 2016 08:17 PM
carlo
24
Oct 5, 2015 08:20 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
