Ford Red Master Key -transponder!!
Old Oct 1, 2008 | 08:11 PM
Aaroncast's Avatar
Aaroncast
Default Ford Red Master Key -transponder!!
-------right listen up!!!!!!!!!!
senario!!------two keys both used to work but one has worn out others fine
so i need a spare!!!!>>>>>>>>>HERE WE GO>>>>>>>>
get your key cut to match your working one.
now the new key will open doors etc etc but wont send message to engine to fire!!!
hence the transponder needs programing------NO IT DONT!!!(WELL YES IT DOES BUT PAY ATTENTION)))--------LIFT THE RED LITTLE CAP FROM YOUR NONE WORKING KEY NOW WITH TWEEZERS REMOVE THE TRANSPONDER AND PUT IT INTO YOUR NEWLY CUT KEY!!!(AFTER REMOVING YOUR RED CAP FROM YOUR NEW ONE-
FINISH BY POPPING THE RED CAPS BACK!!!!!!!-----TWO KEYS WORKING---DUMP THE NONE WORKING ONE OR WHATEVER YOU WANT TO DO-
MOST CAR ACCESSORY CAN PLUG INTO YOU ECU TO READ AND WRITE FROM A ECU-
NO PROBLEMS--------FORD KEEP IT HIGH TO KID YOU!!!
GOING BACK TO MY FIRST PART REGARDING SWAPPING TRANSPONDERS HOW MUCH WOULD YOU PAY NOW!!!!!----------
A COMPANY ON WESTDALE LANE-NOTTINGHAM WILL READ AND WRITE AND SUPPLY YOU WITH A RED KEY(MASTER) AND A STANDARD RED SPOT KEY-----££££££££££60!!!
F--------CK FORDS -ROBBING BASTERS -ALEDGEDLY!!LOL
COME ON FORD EMPOLYEES TAKE ME ON AND SAY IM WRONG!!!!!!!
JUSTIFY YOUR CHARGES -HOW MUCH FOR LEAVING THE CAR FOR HALF A DAY TO SWAP TRANSPONDERS!!!!!!!!!!!!!!!!!!!!!!!!-££££££££££££££££££ COSSY OR NOT
__________________
Become an anal bleacher ----the cracks good!!!!
Old Sep 16, 2010 | 12:12 PM
ryan2910's Avatar
ryan2910
Has anybody else done this? I am struggling to remove the cap. whats the best way to do it?
Thanks
Old Sep 18, 2010 | 02:35 PM
With a strong pin or very small flat bladed jewellers type screwdriver.
borboyous
Aug 22, 2015 11:17 AM
Caddyshack
Aug 19, 2015 07:29 PM
Bailes1992
Aug 16, 2015 07:14 PM
tankybaby66
Aug 9, 2015 07:13 AM
