electronics help no blowers not a ford
Old Oct 1, 2008 | 08:12 AM
999's Avatar
999
Default electronics help no blowers not a ford
hiya sorry its not ford related but a pain in the arse never the less
its an 2000 W reg isuzu rodeo based truck, crew cab pick up type thing, could be a isuzu tf might even be a bit of vauxhall bravo inside who knows lol
anyways no blowers, so i go under dash pasenger side find motor, find two wires going to it, switch on fans and no live going it
so i then move tot he switch, take dash apart find the plug to the switch, its got 6 wires on it, so i test for a live nothing atall, there is an earth there, so i think well ill try put a live down each one of the terminals to see if it puts the motor on and nothing, so i try eart down each terminal nothing
now this confused me as i thought puting a feed down the wore would put the motor on.
what do i do now? i havent tried putting a live to the motor to see if comes on but i expect its ok
a bit stuck and a bit cold in the mornings any help appreciated
Old Oct 1, 2008 | 02:09 PM
999's Avatar
999
up
Old Oct 1, 2008 | 05:02 PM
First try a 12v live and earth direct onto motor to establish it is ok.
Next check the earth on the motor as this is most likely culprit, test the switch again for output as it is getting live supply, the earth at the switch is no doubt a earth for illumination bulb in switch.
Old Oct 1, 2008 | 05:08 PM
focusv8's Avatar
focusv8
There will be a resistor somewhere for speed control.
Ford fits within the heater assembly.
Something like this;
http://cgi.ebay.co.uk/ISUZU-TROOPER-...d=p3286.c0.m14
Old Oct 1, 2008 | 07:34 PM
999's Avatar
999
the ilumination etc is a diff plug, but i will try everything
focus v8 yes i know about the resisters changed a few on transits mondeos etc but i think even if that was goofed it would still have a live at the switch
borboyous
Aug 22, 2015 11:17 AM
Roosie
27
Aug 19, 2015 12:16 AM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
