headlight/sidelight not working.
drivers side i have nothing. i've checked the fuses and pass side is fine. i have main beam on the drivers side but thats it. Is there an earth or something i'm missing?
failing that get a multi meter and see if you get a reading try putting the earth to the body on a good point this should check the earth to light and on the connector try it from the back where its cripped and in the female spad the 2 side ones are main beam and side to top is high beam if i remember rightly if you have a good 12v try the bulb may look ok but you never know
mark2
give them a clean with emery cloth and whack some vaseline in them thou brass/copper and water dont go well together
mark2
i'm gonna get some new holders and re do the spade connections in a few days (prob the weekend) and sort it that way. i stil dont have a side light though,but i'm more than happy with how it is atm, its not so much of a "pull and 3 points" to have a sidelight out. you can kind of blag that one off
do you have voltage at the side lights check at the back first then the connector probaly the same as before just bad connector
mark
Cossikev
Sep 13, 2015 02:00 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
Thrush
Computers, Consoles and I.T.
Oct 5, 2005 11:46 AM
