2.0 zetec turbo valve springs
Ive been advised to replace my standard valve springs if i am running more than 5 psi boost on my blacktop zetec turbo, Is this correct? If so what valve springs do people recomend and will i need to take the head off to change them? I will be running around 1bar of boost. I should be getting it setup on the rollers in a couple of weeks so if they have to be changed i'd rather do it before.
Any help would be apriciated.
Si
Si
They only need chaging if raising rpm or they are weak anyway.
Being turbo'd does not make the valve any heavier, which is why the spring is there to close it, if it has a significantly higher rpm with the turbo then I would or if done over around 50/60,000 it wouldn't hurt anyway.
pipers springs seem to work, but it all depends on how far you want to go with it.
Been looking on the net and ive found some piper springs for Ł155. I have emailed Area 6 for a price. Also found out with the correct tools the springs can be replaced without removing the head
Si
Si
Now sorted, Going to go for the ones from area six, Ł136 delivered
Also as its a blacktop i will need to replace the groove retainers to triple groove retainers from an early zetec.
Si
Si
