Air Injectors Or Apexi Boost Control??
Just want to find out what people think are the best route for controling boost.
I have a p8 with air-air and apparently cant get adjustable boost control which I would like.
Is the Apexi system as good at holding boost as air-air??
apexis are crap at above 30 psi so I would say AIRS why cant you have adjustable boost on the P8 then?
you could even use an AMAL/SEM valve and have a 2 stage boost control is you wanted
ahhh! I want to hold 32psi at times
Im not into ecu,s but im running 8 injecters and anti lag on the p8 and apparently makes it akward to run varible boost as well
I must admit I am not that up on the P8 but I run the same seup as you do. Maybe the trigger for the antilag is an aux that would have been used for the boost pot?!
I am sure some one will be along to confirm. I thought i had seen people with both working on a P8 though!
If running 8 injectors & ALS does that mean I have a super P8 or maybe there another method of running 8 inj ?
Dave
There is not much to set up with them........they will learn with all the take correct inputs.
The profec B solonioid is still better for higher boost control though
how will that give him adjustable boost......................dont think he means getting out of the car and adjusting it each time!
Get a different ecu that will run 8 injectors(if you want 8), and has more than one map, so just a case of flicking the switch, to whatever you have set it to.
I really have never seen the point of loads of adjustable boost points, when your foot can do the same, although I could understand a "wet" lower boost setting esp on a 2wd.
2. Wet track / road use (as when the tyres spin and the revs rise, you get even more boost, and not everyone has the same levels of skill to accurately modulate the throttle).
3. To keep the charge temps down on a really hot day (as just running full boost and hitting the charge air temp retard points in the map will reduce the power more than just keeping it below this threshold by backing off the boost).
4. When you give it to the wife / friend to drive
I am running 2wd and need to calm it down when nessesary, ie in the wet and as Mike says, when you let the wife out in it
what if your running 4 injectors and ALS without a
pectel board, can P8 run an adjustble manual boost pot ?
[quote=rsnissan;3609887]There is not much to set up with them........they will learn with all the take correct inputs.
and you can also set the boost to rpm and can run 2-3 bar with no probs
Mike - I enquired about running ALS on my super 8, but Stu told me it isn't possible to do that and keep the 12 pot boost control? Something to do with it using the same memory locations or something?
I was just wondering how you are able to get round this? My super 8 is based on an L8 if that makes any difference?
Don't mean this to question Stu's knowledge in anyway
I am referring to Super P8, which CAN do both as standard without modification
However, I have no experience on running these ECUs without the boards, so Stu is your best bet for this question
nipper.1
Ford KUGA
12
May 30, 2022 07:39 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
