Focus RS smoking
Old Sep 24, 2008 | 06:40 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
Smile Focus RS smoking
hi guys,my mate has a focus RS which he has just had the turbo replaced on due to it smoking but still smokes.it has 55 000 miles on the clock, FFSH, is running about 260bhp and has the recommended oil viscosity in it.any ideas as to wat is causing the smoke,could it be the valve stem seals as it only smokes when the oil is hot and has been reved?
cheeRS guys.
Old Sep 24, 2008 | 10:59 PM
COCHYN's Avatar
COCHYN
Bit of blow by on the rings maybe? Phone up and go and see Rob Oldman at SCC in St. Albans
Old Sep 24, 2008 | 11:04 PM
RAT8OY's Avatar
RAT8OY
oil left in the boost pipes and charge cooler from the last turbo failure!
Were they cleaned out?
Old Sep 24, 2008 | 11:31 PM
RWD Pete's Avatar
RWD Pete
when does it smoke?idle?under load?
Old Sep 25, 2008 | 10:28 AM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Maybe the exhaust boxes has oil in it or possibly the cat. maybe the intercooler has some oil left in from previous failure as mentioned above
Old Sep 25, 2008 | 10:37 AM
R4N SS's Avatar
R4N SS
thats what im thinking
Old Sep 25, 2008 | 10:39 AM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
^^^What he said^^^
Old Sep 25, 2008 | 11:11 AM
Kverna's Avatar
Kverna
Virgin-popper
What the above said. Fired up a 200sx after a turboreplace.. God damn though it was on fire
Old Sep 25, 2008 | 12:28 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
the RS has done around 50miles since the turbo has been replaced,dont think the pipes were cleaned out tho.wen the car has been reved up then let back to idle it smokes for a bit.its a hybrid turbo that he replaced it with and i was wondering is it maybe needing set up properly as the actuator has not been changed 2 suit the cars performance,unburnt fuel maybe entering the exhaust?
cheeRS guys 4 the replys
Old Sep 25, 2008 | 12:42 PM
tobyjug_1988's Avatar
tobyjug_1988
we get a few in at my place smoking after u replace the turbo, they usually smoke for a whie aswell.
Old Sep 25, 2008 | 02:43 PM
RichieST's Avatar
RichieST
just keep an eye on the oil level and see if it drops...
Old Sep 25, 2008 | 02:45 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
What colours the smoke?
TPM961
Jan 15, 2018 10:50 AM
massivewangers
30
Oct 1, 2015 07:40 PM
RSMK4TURBO
Ford Focus RS
14
Sep 19, 2015 06:27 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
turbowag
Sep 3, 2015 08:07 AM
