Towing an ESCOS on 2 wheels...
Resident Wrestling Legend
if you drag teh car with the front wheels in the air, you'll probably get a few hundred yards before the viscous coupling is fucked
in good condition the rear wheels will be pushing the fronts along but you really need to work out the internals of the viscous coupling to get your hear around it, once you do, it's easy as
the viscous locks the front and rear output shafts of the gearbox together, and it always does this if the car is moving or not
when you put your foot down, the torque is sent 2/3rds to the rae and 1/3rd to the front due to the different sized cogs in the transfer box so you have permanent 4wd all the time
the reason you see if making a big difference when you go round corners is that the front wheels are "driven" and are pulling the car around the corner (akerman steering principle, i'm sure someone will be able to enlighten everyone more about it and the fact that the front wheels take a longer route around a corner than the rears do etc, etc)
so when the rea prop is being turned, it's turning the front prop at the same time
if the viscous fails you can still drive the car because the front and rear props are rotating at the same speeds so the transfer box thinks everything is working fine
when you go round a corner though, all the spinning goes to the front so you lose a lot of power that way
Cos500
16-09-2015 09:50 PM
