Indesit Tumble Drier Help
Following on from the waching machine thread the other day, does anyone know how to fix an indesit tumble drier. It comes on and spins, but it stays cold. I've emptied the fluff things and water tray. To my expert brain
it would seem like the element is knackered. Is there any way of testing?
We have a washer/dryer and our dryer used to be like yours spin but not get hot and i was told to remove the top then there are 2 little buttons which trip i just pressed these and it now works yours may be simler
Brian
Brian
Sorry i can't be more specific but as said above it's a wee switch you need to push in.
ive just fixed my indesit dryer i removed a panel of the back and there was 2 silver round thingys i tested them and 1 was broke so i bought a couple of the net for Ł26 fitted em and it works a treat (touch wood)
orion=mini saff
one shot thermostat tripped,2 ways,u can either either give me the part number and i'll post a set out to u or if u take the back panel off and removed the 2 scews holding the heater in,theres 2 stats on top,one has a small hole init big enuff to push a paper clip init to pop it back,tho it does go for a reason,give me the model number and i can help more
orion=mini saff
http://cgi.ebay.co.uk/HOTPOINT-CREDA-Tumble-Dryer-THERMOSTAT-KIT-Gen-1703200_W0QQitemZ370086683636QQcmdZViewItem?hash=i tem370086683636&_trkparms=72%3A12|39%3A1|66%3A2|65 %3A12|240%3A1318&_trksid=p3286.c0.m14
set for it here,if not i can post u set out if i got some on my van
orion=mini saff
nah,just means u were lazy and didnt empty the water
if the lights on it wont heat also, so just asked!
there pretty sensitve dryers,normally they trip due to the condenser and filter not being cleaned regular enuff!
glad its working bud
