fiesta turbo running issues
hi ive got a fiesta turbo engine in my xr2 running ofab managment its not chipped or anything running a standard t2 the problem is when it boosts it goes to 1.2-1.4 bar which i know is not right . i thought it was the actuator changed it but still does the same thing does anybody know what it could be ? cheers
First thing I would do is run a pipe directly from snale (turbo compressor housing ) to the actuator , therefore bypassing all the electronics and see if this drops boost , if it brings it down massively then you are either looking at a stuck boost solenoid or faulty wiring from ecu to solenoid valve . Would then put it back see if you can borrow a different valve then if it still overboosts , if it does then will have to disconnect ecu and check continuity from solenoid valve to ecu connector .
Hope this helps
Hope this helps
JoeyBoyden
Jan 4, 2024 02:36 PM
Red_bull
Aug 9, 2015 08:34 AM
