Autronic rev counter
Old Sep 19, 2008 | 05:22 PM
MalteseFalcon's Avatar
MalteseFalcon
Default Autronic rev counter
Hi to all, my mate just converted his Escort Cosworth to Autronic Ecu and wasted spark but is having problems with the original rev counter. It either revs slowly or twice it's actually reving. Any one can help please?
Thanks
Old Sep 19, 2008 | 05:25 PM
morty's Avatar
morty
Possibly the wiring is a bit dodgy?
Old Sep 19, 2008 | 07:25 PM
Mark Shead's Avatar
Mark Shead
Thanks
You need a Autronic tacho adaptor this will sort out the rev counter issuse.
Mark
Old Sep 22, 2008 | 02:55 PM
MalteseFalcon
hi Thanks for the help
Old Sep 22, 2008 | 02:59 PM
MalteseFalcon
My other friend converted his escort to Autronic before and used the tacho adapter with no results! But we'll try our own if you say so! Thanks for the help
Old Sep 27, 2008 | 11:01 AM
MalteseFalcon
can anyone tell me where I can buy a tacho adapter for the sm4 ecu?
Old Sep 27, 2008 | 01:25 PM
Nash's Avatar
Nash
Cake lover!
PM Mark Shead above he will be able to tell you.
Old Sep 27, 2008 | 02:36 PM
If it's a simple square wave convertor you need, there are others that do the job, I fitted one to mine, as tacho did not work with new emerald ecu, cost me £30, and a emerald part, so all easy, that was because I went from std coil to coilpack so needed a square wave signal.
Old Oct 4, 2008 | 03:05 PM
MalteseFalcon
Sorry being a bit ignorant but what should I do for this square wave signal and how should I fit it? Thanks
Old Oct 5, 2008 | 08:23 AM
Dave Henshall's Avatar
Dave Henshall
the std escos rev counter wont accept a basic square wave input, it needs a colappsing field back emf which peak to peak is much higher voltage than teh square wave
TPM961
Jan 15, 2018 10:50 AM
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
cozzy jeff
Aug 14, 2015 05:46 PM
