anyone help with missfire
hi. im currently on with putting my s1 back on the road and im having trouble with missfiring under boost but only once warm, i know it does need a gud set up but i dont want to take it some were to be set up and end up fitting parts all day long to cure this problem first, cheers mark
Hi Mark i would start with basics ie plugs, leads, etc etc and make sure everything is spot on, could be the plugs breaking down once temps get high or the leads etc etc...
As for the boost what spec is the engine and what boost are you running ?
Chris.
Chris.
Ginge !
23
May 28, 2005 01:06 PM
