arp stud and nut kit for 1.6 cvh!
Sep 13, 2008 | 11:51 AM
best place to buy from??
thanx for reading!
Sep 13, 2008 | 02:45 PM
Do you mean head studs/nuts?
I have a set here that have been used once (they are re-usable apparently).
Sep 14, 2008 | 09:45 AM
Dont bother buddy, stick with ford original bolts and use Arp con rod bolt
set
Matt Lwis does the rod set for £50
Sep 14, 2008 | 10:27 AM
Quote:
Originally Posted by
Christian and Beccy
Ive already told him that but he dont listen to me
Sep 14, 2008 | 06:22 PM
Kristoff28
set
ive got them on my rods but need the arp headbolts
bad boy rs
i must check from people that understand cars properly ! ur a bloody builder !
Sep 14, 2008 | 07:38 PM
s1cab
an engine builder
Sep 14, 2008 | 07:41 PM
Stick with the ford stuff its alot cheaper and well up to the job aslong as they are fitted to cleaned lightly oiled block threads.
Most failures are due to careless installation causing incorrect torque readings.
Sep 14, 2008 | 07:46 PM
I dont think the standard ford ones are up to the job in this case, hes running 300+
on the 1600 and having problems with the head lifting
Sep 14, 2008 | 08:55 PM
bad boy rs
an engine builder
bad boy rs
very good u remember !
Cosnada
Jan 7, 2016 05:30 PM
sridgett
13
Sep 27, 2015 06:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
focuspower
Sep 20, 2015 03:51 AM
focuspower
Sep 19, 2015 08:27 PM
