Brake Clearence on 356mm Disc on 17" Wheels
Old Sep 8, 2008 | 03:22 PM
Sonic Boom's Avatar
Sonic Boom
Default Brake Clearence on 356mm Disc on 17" Wheels
I've got Compomotive 8 x 17" Grp A Fitment ET33 and wanted to know if I could get 6 Pot AP's with 356mm Discs under.
I measured from the centre of the Alloy to the inside egde which gave me a measurement of 205mm I then got a CAD drawing (see below) that give me a measurement from the centre of the disc to the outside edge of the Caliper of 197.66mm So i looks like they will clear by 7.34mm.
But the question is do you thing this enough clearance?
Cheers Rich
Old Sep 8, 2008 | 04:00 PM
rinus_2005's Avatar
rinus_2005
the radial clearance seems to be ok, however it depends where the rim/wheel starts to get thicker going towards the spokes. So the axial clearance could be an issue
Last edited by rinus_2005; Sep 8, 2008 at 04:02 PM. Reason: my crappy english....:-(
Old Sep 8, 2008 | 04:27 PM
jon@work's Avatar
jon@work
I've got the old flat 5 spoke MOs ET40 with 356mm discs and AP 7040 6 pots - I had to design the bell to be a few mm deeper than usual, but they fit fine (2wd)
Old Sep 8, 2008 | 04:43 PM
Sonic Boom's Avatar
Sonic Boom
Was that to push the caliper further away from the inside of the spokes?
Cheers Rich
Old Sep 8, 2008 | 05:08 PM
jon@work's Avatar
jon@work
Cheers Rich
Yes - I've got sets of ET40, ET35, and ET33 wheels (and some ET25 RL7s), so the 40s were the worst case from a clearance point of view, and were thus what the bells were designed for.
Old Sep 8, 2008 | 07:53 PM
Sonic Boom's Avatar
Sonic Boom
So with mine having and offset of ET33 it should clear ok?
Cheers Rich
Old Sep 8, 2008 | 08:19 PM
jon@work's Avatar
jon@work
Cheers Rich
I would think so, if the car is 2wd and you can make the bells deep enough. You'd be best off asking Martin Hadland.
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
hopper350
Sep 4, 2015 12:53 AM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
borboyous
Aug 22, 2015 11:17 AM
