No power below 4000rpm
Old Sep 7, 2008 | 09:50 PM
spookie's Avatar
spookie
Talking No power below 4000rpm
I have nothing doing below 4000rpm then she pulls light a good un?? and miss fires at low revs speshly when in high gears.( 30moh in 5/4 gear mainly) i run it on high octane fuel or v-power, and have new plugs and leads.. any help???
Old Oct 30, 2008 | 06:01 PM
MikeXR2t's Avatar
MikeXR2t
i have exactly the same issue, if anyone can shed light on the subject that would be sweet. ive tried cam timing, fuel pressure, injectors and different boost levels
Old Oct 30, 2008 | 07:42 PM
witto's Avatar
witto
zetecs suffer from plugs leads and air flow meters, n they all give that kind of effect, but if you've had plugs and leads try unplugging your air flow meter, it will go to a base setting, so it should run OK with it unplugged if its faulty! my old xr3i 130ps was the same, unplugged air flow meter plug and it was fine just a bit fuely! then bought another off ebay for a 10er! but in the worst case it could be a valve burning out or head gone pourous!?.... try AFM first tho its free 2 try lol.
Old Oct 30, 2008 | 08:43 PM
PAULDOLMAN's Avatar
PAULDOLMAN
check for any air leaks, make sure jubilee clips are all tight
Old Oct 31, 2008 | 12:05 PM
MikeXR2t's Avatar
MikeXR2t
except mines an eight valve turbo! running OFAC so theres no AFM. with the zetecs they sometimes grumble on no 1. you can pull the injector plug off and theres no change in engine behaviour till around 4k. correct me if im wrong but ive found that means youve done a valve! the flat spot on mine feels like theres no fuel or something then as soon as it hist 4k it spins the wheels and fcuks off big time. i guess its not fuel though as it pulls later on in the revs where it needs most. havnt tried pressure regulator because i can hear the pump change note as i touch the throttle, so something is happening. its been fine for ages thenone evening bam, no power under 4k. on a good rag its not an issue cos it never goes under that but on hills and stuff its a bit poo!. checked all boost pipes and it boosts and hold just 1.2 bar (on a stage one chip but im not complaining lol). any ideas on the ignition timing setup. it could be backing off somehow. at 4k it has a wee stutter just before it kicks in. its driving me mad!!!!!!! HELP
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
phil51
Ford Focus Diesel
Oct 2, 2015 01:00 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
deathrider666
Sep 28, 2015 06:12 PM
