MK6 Steering
Old Sep 7, 2008 | 07:24 PM
ff123's Avatar
ff123
Default MK6 Steering
At last, had the time to look at my steering !!
The problem was excessive play even when steering lock is on (can still be pulled about 3cm towards you)
Anyway the problem is at the rear of the colum leading to the steering arms you can see the slack when pulling towards you .It is also very greasy
looked my haynes manual and its vague
anyone got any ideas how to cure !!!!!???????????
cheers
Old Sep 7, 2008 | 08:40 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
If it's not the column adjuster then you probably need a new column.
Old Sep 7, 2008 | 09:01 PM
ff123's Avatar
ff123
how do i adjust colum??
Old Sep 7, 2008 | 09:11 PM
Dangerous Malcolm..
If it has an adjustable column it'll have a lever underneath on the right hand side.
Old Sep 7, 2008 | 09:13 PM
ff123's Avatar
ff123
is that the one that locks steering wheel in place after adustment ??seat posision etc
because if it is its not at fault ???
Old Sep 7, 2008 | 09:32 PM
Dangerous Malcolm..
Yeah, that's the one I mean. If it's not that then it sounds like it could be bust then fella.
Old Sep 9, 2008 | 08:56 PM
ff123's Avatar
ff123
the colume is not bust but its holded by a spring
is this to blame if it was colume it would be all over the place
any ford mechanics on here help !!!!!!!!!!!!!!
Old Sep 9, 2008 | 10:41 PM
ff123's Avatar
ff123
tankybaby66
Feb 6, 2016 02:24 PM
IainRS1700T
Sep 25, 2015 06:44 AM
dange
Ford Mondeo Including ST
Sep 23, 2015 12:11 PM
dirtysteve
Ford Focus ST
Sep 16, 2015 05:29 AM
