wrc zetec turbo???
Old Sep 6, 2008 | 05:47 PM
rst-g's Avatar
rst-g
ZETEC TURBO
Default wrc zetec turbo???
anyone know why the is a spacer block-decomp plate between the head-block? its a wrc engine.
Old Sep 6, 2008 | 05:50 PM
Davey8oy's Avatar
Davey8oy
it might have something to do with running liners in the wrc blocks??
Old Sep 6, 2008 | 05:51 PM
jacko's Avatar
jacko
may be stroker
Old Sep 6, 2008 | 05:52 PM
rst-g's Avatar
rst-g
ZETEC TURBO
never thought of that
Old Sep 6, 2008 | 05:53 PM
jacko's Avatar
jacko
it may have longer rods and throw so needs longer linners and taller block with spacer like reyland escort has
Old Sep 6, 2008 | 06:49 PM
Big Will_'s Avatar
Big Will_
Borg Warner EFR Equipped!
From: In the unit, building a 450bhp Time Attack Focus!
It was the same on all the zetec WRC engines - the liners sit proud of the bores by around 12mm and the plate goes on top before the head.
Never did get to the bottom of why!
Old Sep 6, 2008 | 07:49 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Because you do absolutely anything you can to gain torque (and thus power) when you're running a 34mm restrictor at this level!
Old Sep 7, 2008 | 07:48 PM
AustenW's Avatar
AustenW
It was so that they could run longer rods to get the rod ratio up using the 88mm crank t extract more power and torque and make it rev better
Also used wet liners to, plate and liners were also designed to aid cooling around the top of bore as the engine was high comp and suffered from heat.
I've had a WRC engine in bits
Old Sep 7, 2008 | 08:07 PM
SiZT's Avatar
SiZT
and now to rack your brains even more!!! where can I get a idler pulley like the one in that pic for a ribbed fan belt
Old Sep 7, 2008 | 08:16 PM
AustenW's Avatar
AustenW
Its the drive for the water pump
no longer available
Also uses different offset so would not fit a standard engine
robnock
21
May 13, 2019 05:29 PM
robnock
Aug 22, 2015 10:51 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
