Con Rod Help.
Old Sep 4, 2008 | 11:58 AM
bob_series1's Avatar
bob_series1
Default Con Rod Help.
Hello all.
My question is, are the con rods from a 1.8l silvertop zetec engine the same as the con rods from a 2.0l silvertop Zetec.
Reason.
The reason i ask is i am building a ZVH from a blacktop engine. So with i bought a Silvertop now. Anyways. My C20XE mahle pistons came today so i am very excited to collect the rest of my parts. I will go to the scrap yard this weekend and take the sump, pickup pipe and flywheel of a 1.8 zetec but i still am in need of pistons. I do not want to take another engine to bits for the pistons if i can do it all from the one engine. Any Ideas?
Bob
Old Sep 4, 2008 | 01:23 PM
Red16's Avatar
Red16
As far as im aware the crankshaft and rods are the same in the 1.8 and 2ltr silver top zetec engines.
Old Sep 4, 2008 | 02:12 PM
bob_series1
So no difference in the length and the size of the small end then?
Old Sep 7, 2008 | 07:59 PM
pdfbt40's Avatar
pdfbt40
No, as Red16 said, they're the same.
AFAIK there were only 4 different rod dimensions made by Ford.
'Silvertop'
'Blacktop' European
'Blacktop' FRS
'Blacktop' American (Normal & SVT{ST170}, but same dimensions)
Martin
Old Sep 9, 2008 | 11:15 AM
bob_series1
Default Thank you
Wow, that is a great answer.
Thank you both!!!!!! I will jot that down.
muzzman1
Sep 30, 2015 08:59 PM
stevecfrst1
Sep 30, 2015 05:18 AM
little bram
Sep 27, 2015 07:45 AM
S3an
Sep 26, 2015 11:39 PM
coscor86
Sep 20, 2015 01:21 PM
