L8, wasted spark, crank/cam trigger...etc.
Old Sep 1, 2008 | 07:30 PM
Rs1's Avatar
Rs1
Default L8, wasted spark, crank/cam trigger...etc.
I'm not into the cossie side of it much so bare with me...........
What coil(s) will the wasted spark conversion drive? More specificly would it drive a coil unit like those from a astra coupeT/vxr...1 big coil unit direct mounted above the plugs?
With the wasted setup is the redundant dizzy used as a hall/phase pickup or do you require a pickup mounted into the cam cover and mod'd cam?
Whats the crank pully trigger configuration...teeth wise.
Old Sep 2, 2008 | 06:47 AM
Assuming you are reffering to a wasted spark conversion on a weber marelli ecu,
The crank pulley stays exactly the same, and still uses the phase sensor in it, just not the rotor arm or dizzy cap(most leave on or get a cover).
With this you do not require a cam mounted trigger, but could have it as an alternative if desired.
I can't see any reason why the conversion would not power the plug on coils you mention, but not 100% sure, so I would check with stu etc, but assume you will need a ignition driver for each coil.
Old Sep 2, 2008 | 07:26 PM
Rs1's Avatar
Rs1
Ok, cheers.
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
DixieTheKid
Sep 14, 2015 09:04 PM
