S1 no spark, help!
Old Aug 31, 2008 | 06:04 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Default S1 no spark, help!
As above no spark, traced it back as far as coil, tried a plug on the end of the king lead to the battery earth terminal turned it over and nothing.
Tried another coil and king lead same result.
Tried this same test on my S2 and sparked with no probs, so where do i go from here? ECU? or dodgy wiring maybe?
Bit stuck now!
Old Aug 31, 2008 | 06:12 PM
Lee Ivatt's Avatar
Lee Ivatt
Shizzle My Nizzle
when i rebuilt my S1 we spent 3 days trying to find the cause of no spark. relpaced everything with no luck.
turned out it was a small green wire!!
There is a green wire which runs from the coil to the fuse box. It runs round the headlights and rad and back up to the box, coming in and out of the loom.
It may be worth checking this and bridging it to see if its the cause, as the wire is part of the circuit responsible for the 'hall effect' distribution.
I was lucky in the respect that my mate is a ford technitian, so we managed to borrow a "break out box" (an early diagnostics tool) which drew us to the green wire.
Old Aug 31, 2008 | 06:17 PM
Karlos G's Avatar
Karlos G
Balls Deep!
I'll check that thanks!
Old Aug 31, 2008 | 07:02 PM
haz87's Avatar
haz87
Checked the earth?
Old Aug 31, 2008 | 07:12 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Which earth in particular?
Old Aug 31, 2008 | 07:24 PM
Zetecfiesta's Avatar
Zetecfiesta
try checking that its not earthing out, my mates series 1 would sometime run and sometimes not and it was traced to an absolutley tiny bit of bare wire touching the car!
Old Aug 31, 2008 | 07:26 PM
Barry R's Avatar
Barry R
believe it or not i had the same prob on my series 1 it turned out to be the little
earth wirethat screws next to the wiper moter.
I found it by accident when we were turning it over and leant on the wire which
earthed it out and we had a spark, so screwed it down tight started straight away
Old Aug 31, 2008 | 07:32 PM
rickbartlett's Avatar
rickbartlett
G911 TTA
i had same prob b4
Old Aug 31, 2008 | 07:54 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ok so earths and shorts!
I'll get onthe case tomorrow!
Cheers!
Old Aug 31, 2008 | 10:05 PM
L3 COS's Avatar
L3 COS
yes as above, if you,ve removed the heater blower from under the bonnet and took off the earth wire next to the wiper motor, well i believe the other wire is an earth for the ecu and wont spark without it connected,so check for good earth there, other than that sounds like possible distributor packed up? or dodgy plug on it?
Old Aug 31, 2008 | 10:39 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Yeah i'll check that tomorrow sounds promising!
As I said it's the coil not producing a spark, not getting as far as the distributer!
Old Sep 1, 2008 | 08:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Ok all earths checked, all wires continuity checked right back to ECU!!
If the sensor in the Distributer was dead (plug on top), would that not sending it's signal to the ECU prevent it from sparking?
Old Sep 1, 2008 | 09:09 PM
boothy's Avatar
boothy
is the plug loose on top of your dizzy check that get a mate to turn it over and try moving plug ,sometimes the wires are bare where they have been rubbing away JUST A THAUGHT MATE.....
Old Sep 1, 2008 | 09:33 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Would that prevent the ECU from signaling the Coil to spark? Cos yes it is loose.
Old Sep 2, 2008 | 08:23 AM
Karlos G's Avatar
Karlos G
Balls Deep!
Changed Distributor........ sorted!!
Fired up first time!
Old Sep 2, 2008 | 08:35 AM
craigos's Avatar
craigos
could be the dizzy mate the wires break inside and it breaks the whole circuit,had this 2s on the s1s ive had
Old Sep 2, 2008 | 09:46 PM
L3 COS's Avatar
L3 COS
i did say distributor, oh and yes if the dizzy has packed up you wont get a spark from the coil as the dizzy triggers the coil to spark on a rs turbo.
sorted!!! ;0)
Old Sep 2, 2008 | 10:11 PM
boothy's Avatar
boothy
good man sorted.....
Old Sep 3, 2008 | 03:09 PM
s1 abz's Avatar
s1 abz
these r the sort of problems i fukn hate, gets ya running round in circles
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
