silly problems
Old Aug 29, 2008 | 04:22 PM
dom123's Avatar
dom123
Default silly problems
hiya, i'm new to my escort cos having owned it a week, lovely motor but the dash needs completly refiting!! which i don't mind as it isnt scratched, just nothing works!! so i'll be needing lots of advice i'm sure!! after taking my car out the other night i notice a horible mess behind the dials when there lite up, mainly the boast set, so ive taken them out but i can't get to where it is, to clean it out, are the gauges white standard? if not perhaps it the glue i can see holding the white paper in... how much are a new set, what are they called?
cheers
james
Old Aug 29, 2008 | 04:33 PM
El Grand Tomismola's Avatar
El Grand Tomismola
The dials are Electro Luminestent sheet.
So basically they glow when a electrical current is passed thru them.
Unfortunatley the sheet starts to deteriorate after many years and black "blobs" appear.
This I gather is what is happening to yours. Has your speedo, rev counter etc started doing the same?
You can easily fox the problem by replacing with new (if still availiable) or the easier option is to get a set of Briba dials.
This is a common problem, so your not alone
Old Aug 29, 2008 | 04:48 PM
dom123's Avatar
dom123
yer they have mate i understand now! whats Briba dials are they direct replacements? where can i get them from? do they make the speedo as well?
cheers
Old Aug 29, 2008 | 06:13 PM
grcossie's Avatar
grcossie
Not Briba, but Birba, here you go
http://www.birba.com/shop/customer/home.php?cat=18
Old Aug 29, 2008 | 07:19 PM
dom123's Avatar
dom123
thanks for the link do these only come in kilometre readings?
cheers
Old Aug 29, 2008 | 08:03 PM
Speedy G.'s Avatar
Speedy G.
Nopez, you can also get them in mph and I still have a set laying about over here.
Old Aug 29, 2008 | 09:41 PM
redrsmk5's Avatar
redrsmk5
Hello and welcome to the site! Easily cured problem mate, scour ebay if you want standard otherwise the birba dials are very good, but if you do buy standard of ebay or anybody else be sure to buy the right main dials as Small turbo and big turbo are different.
Put some pics up of your car
Old Aug 30, 2008 | 07:52 AM
dom123's Avatar
dom123
thanks how do i tell which ones are small turbo or large my cars a small turbo model but i'm conviced the dash has been changed as its all loose, its on my jobs to do list are all the birba dials universal between the large and small i like the idea of the birba 2bar boost set.
Old Aug 30, 2008 | 10:34 AM
El Grand Tomismola
Dam my spelling LOL.
Old Aug 30, 2008 | 10:37 AM
Kelv's Avatar
Kelv
Almost there!
MPH mate.
http://www.birba.com/shop/customer/p...cat=200&page=1
Old Aug 31, 2008 | 09:19 AM
dom123's Avatar
dom123
this is turning to a nightmare, ive now lost all the dash lights and the rear tail lights and fog lights, sometimes i had to turn the headlights on twice for the dash lights to come on so somethings not right now its packed up all together!
Fuel gauge is up and down again
Clocks have splodges everywhere..
No windscreen spray.
aircon dont work.
Im gonna rip the whole interior out and start again!! I cant take anymore!! Do i need to take the steering wheel off to get the clocks out? if so how do i get round the airbag and cover.
So fustrating as the cost of these cars are the same a e46 m3 cab, evo 8,
I did get the car for a fair price to be honest off i nice bloke just hoped for a couple months hastle free!!lol
cheers
Old Aug 31, 2008 | 09:23 AM
pee vee's Avatar
pee vee
if the rear lights aint working
The problem is the stalk
Old Aug 31, 2008 | 02:27 PM
fish99's Avatar
fish99
Have you checked the illumination brightness switch.. I lost all my dash lights and banana pod lights... Then I realised the illumination switch wasnt pushed all the way home.
I know what you mean about the lights as they are pain in the bottom.. biggest problem I had was dodgy earths on the fronts.
Old Aug 31, 2008 | 02:54 PM
Kelv's Avatar
Kelv
Almost there!
Dash lights and rear tail lights often are the stalk switch, but first check the dimmer control in the lower dash section.
the fuel gauge wiring is possibly as mentioned before on another thread, but check all the connections under the rear bumper and around the tank - they do suffer alot of degredation and corrosion over the years
the other electrical issues could be down to the fuse box, which is another issue which catches out several escos owners, these arnt the end of the world to change, but make sure you get the right one if you decide to change it, or you could have it repaired.
personally i think it could be a worthwhile investment in getting it to a decent recomended auto electrician.
where abouts are you from?
Old Aug 31, 2008 | 05:21 PM
dom123's Avatar
dom123
thanks for your replys i'm going to gambe a new stalk i have fiddled with the dash switch and made no difference unfortuanatly, ive pulled the dash out today the clock wire and the fuel warning light and the centre consel lights, werent even pluged in!!! i'm buying new clocks and a new stalk and loads of new black screw and puting it back in perfect,
cheers
Old Aug 31, 2008 | 07:03 PM
pee vee's Avatar
pee vee
how come that lot was unplugged do you reckon?
seems a bit odd.
Rod-Tarry
75
Oct 13, 2015 04:44 PM
DAZZER
Sep 30, 2015 08:43 PM
SMILER258
Sep 28, 2015 09:04 AM
Russ Payne
Sep 25, 2015 08:29 PM
