what does it mean when a car "BOGS DOWN"
Old Aug 24, 2008 | 02:47 PM
cheeky dog's Avatar
cheeky dog
Default what does it mean when a car "BOGS DOWN"
as above,
is that when wheel spin kills the power (turbo charged cars) on front wheel drive cars?
i get that alot on the focus st when changing too aggresively from 1st to 2nd, wheel spin then the power just gets killed!
i've heared the term bogging down quite alot now but not too sure if its what im experiencing?
Old Aug 24, 2008 | 02:51 PM
sbd16v's Avatar
sbd16v
the car have more grip than power basically so the engine revs die to much causing a bad start
Old Aug 24, 2008 | 02:52 PM
Rab's Avatar
Rab
Fucking superstar........
Originally Posted by cheeky dog
as above,
i've heared that term quite alot now but not too sure what it is?
Is that not traction control on the ST. Bogging down is when you're not using enough revs and the grip causes the revs to drop on the start line.
Old Aug 24, 2008 | 02:56 PM
Ginge !'s Avatar
Ginge !
just finding my feet
basically not enough gas when launching meaning you have to dip the clutch and tap the throttle to get back the power,,,, but lost the launch anyway
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
The term 'bogs down' can be applied to lots of situations and just means a slow down.
In your case when changing from 1st to 2nd your road speed isn't high enough when you go for 2nd, so bounce it off the limiter a bit longer and keep your foot flat on the throttle when changing, that way you will maintain your wheelspin and look cool.
Old Aug 24, 2008 | 03:15 PM
mechanic28's Avatar
mechanic28
In your case when changing from 1st to 2nd your road speed isn't high enough when you go for 2nd, so bounce it off the limiter a bit longer and keep your foot flat on the throttle when changing, that way you will maintain your wheelspin and look a fool.
Old Aug 24, 2008 | 03:17 PM
cheeky dog's Avatar
cheeky dog
pretty sure its not the tc coz the revs are still up there but turbo's not kicking on full chat and neds time to get back up.
was driving my friends evo 5 and got the same problem while i was on the gas at about 50mph, hit a massive pot hole and killed the power, boost dropped of completely for a few secs.
Old Aug 24, 2008 | 03:20 PM
cheeky dog's Avatar
cheeky dog
the wheels are quite big so to keep the wheel spin going takes a bit more heart and heavy foot, my old rs turbo had 16" wheels and same scenario was easier to keep the power on but maintian long wheels spin.
Old Aug 24, 2008 | 03:26 PM
cheeky dog's Avatar
cheeky dog
thanx for the info dude, never knew there was a word for the scenario. lol
steerfromdarear
28
Jan 29, 2016 06:14 PM
Shows & Track Days
Aug 26, 2015 05:11 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
