black top zetec turbo rover inlet prob
Old Aug 24, 2008 | 11:51 AM
xrsi's Avatar
xrsi
Default black top zetec turbo rover inlet prob
Right im having probs fitting the rear mounted alt back onto the engine now that i have the rover inlet on
does anyone know if people have fitted the rover inlet to a black top and still used the rear mounted alt?
if so what alt has everyone used?
does it make a diff if its from the mondeo or focus as i have got a 105amp alt off a mondeo that i tried to fit and it wont go anywhere near the mountings cos of the inlet fowling it.
Old Aug 24, 2008 | 01:17 PM
Ginge !'s Avatar
Ginge !
just finding my feet
mate have a look at other options from other companys perhaps, its realitvly simple to look at if you get a idea in your head then contact someone like soverigns for info
done it a few times at work for people
Old Aug 24, 2008 | 06:29 PM
xrsi's Avatar
xrsi
no i mean the inlet is where the alt would go!
the mountings on the alt is exactly the same as the focus item as is the bracket but i was wandering if the physical size was any different, as it looks like any one would fowl the alt.
i know people have fitted the rover inlet to black tops but do they the mount the alt at the front or something as that is not something i would like to do...
Old Aug 24, 2008 | 06:38 PM
rst in breaking's Avatar
rst in breaking
every zetec i can personally think of has a front mounted alternator tbh, what car is it going into?
Old Aug 24, 2008 | 08:21 PM
xrsi's Avatar
xrsi
going in a mk 3 fiesta, but as im using a black top zetec i want to keep the alt at the back as i want to move the coil to the front of the engine above where the alt would sit so i can have the turbo over the gearbox
Old Aug 25, 2008 | 03:58 PM
rst in breaking
can the alternator not go at the front like most and earth the coil pack bracket elsewhere? would the alternator physically work at the back? in my escort the water pump pulley is very close to the engine mount bracket so wouldnt be poss to have it at the back and probally simular in a fezzy?
Old Aug 25, 2008 | 05:01 PM
crazycage's Avatar
crazycage
it fits on the front fine
Old Aug 26, 2008 | 05:32 PM
xrsi's Avatar
xrsi
yeah i know you can use the front mount alt off a zilver top but didnt really want to as the alt would then be right where i am planning to fit the coil and also want to keep it to the back of the engine if at all poss as the wiring will be neater with the rear mount starter and also its out of the way at the back and in the origional position for the engine with it being a black top
Porplus12
Sep 10, 2015 07:20 PM
Chopshop85
Aug 17, 2015 06:38 PM
gingerturbo
Aug 11, 2015 09:44 PM
turbobill
Aug 9, 2015 05:21 PM
Cameron
14
Aug 9, 2015 06:28 AM
