anyone got pics of a cossie with 34-1 trigger wheel fitted
Old Aug 21, 2008 | 09:48 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
Default anyone got pics of a cossie with 34-1 trigger wheel fitted
preferably on a 3 v type using standard sensor just want to show someone something
thanks
Old Aug 21, 2008 | 09:51 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Would that be 36-1?
Old Aug 21, 2008 | 10:42 PM
Roosie's Avatar
Roosie
that would lol
Old Aug 21, 2008 | 10:48 PM
J1mbo's Avatar
J1mbo
B1mbo
if you dont get any tonight i may be able to get some tomorow ill look for ya if i remember lol
Old Aug 21, 2008 | 10:58 PM
Roosie's Avatar
Roosie
cheers
Old Aug 21, 2008 | 11:25 PM
Jay,'s Avatar
Jay,
Sponsor
if ur useing a 2wd sump you will need to space the sensor out 10mm and set the crank angle to 80 degree
Old Aug 22, 2008 | 05:52 AM
Roosie's Avatar
Roosie
why do you have to space it out 10mm?
Old Aug 22, 2008 | 07:12 AM
Jay,'s Avatar
Jay,
Sponsor
sorry should of asked is it a ford pulley
Old Aug 22, 2008 | 07:44 AM
Roosie's Avatar
Roosie
for a sierra cosworth 3 v pully
Old Aug 22, 2008 | 08:59 AM
When I used a std ford pulley, I machined off the 4 lugs, and after marking the trigger wheel, welded it to the rear of the std ford pulley, always measuring everything.
Result put it on, gap is still within tolerance and the sensor and it's bracket are not even touched, nothing at all to do, went straight on without problem.
I used a 5 1/4" pulley, and got it within 1.2 degrees of TDC so bloody good really.
My car is 2wd cossie.
Old Aug 22, 2008 | 09:39 AM
Jay,'s Avatar
Jay,
Sponsor
ok roosie if your useing a 36-1 cossie item then the pulley is slightly larger diameter so it will will need spacing
Old Aug 22, 2008 | 10:43 AM
Roosie's Avatar
Roosie
no im getting a custom one made without the lugs but a 1 peice item
Old Aug 22, 2008 | 12:25 PM
Although of course you could use 36-1, 60-2, 36-2(rover), 36-4(rover), 36-4(rover different one)12-1 yamaha, 24-1 suzuki, 60-1 jaguar, 36-2 toyota, 48-2 ducati, 8+P suzuki, 12+P honda.
So you have a large choice that will work with this ecu!!
On a std cossie item I just machined the rear to the inside diametre of the trigger-wheel.com wheel (5 1/4") and took out the correct amount from the std pulley to enable perfect alignment, did not even need to adjust gap, a bit tricky to do as only one chance to get it right(or bollocks it up!!).
JoeyBoyden
Jan 4, 2024 02:36 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
cossie4x4
Aug 14, 2015 06:29 PM
RsS2daz
Aug 14, 2015 05:26 AM
bassboy
Aug 8, 2015 10:21 AM
