Hi, the last couple of days Ive noticed a loud creaking noise which seems to be coming from the front, possibly the suspension when I turn either left or right!
Anyone had the same problem or known what it could be?
Not really got a clue but I guess suspension related?
its normally an indication of knackered suspension top cups,they break up,pop the bonnet and remove the top nut of the shock,remove the top plate and look inside the hole to see if you can see bits of broken metal
Also, check on the inside of the car where the steering rack passes through the bulk head and see if the big metal clip is all the way down to the bulk head holding the bushes in properly
Mine had this and made knackering noises so big change its that
same as mine, this should short your problem out mate
