zetec turbo (blacktop) water pump solution
Aug 13, 2008 | 02:48 PM
Its actually an st170 engine but same size hole!?
Fit electric pump?
Some sort of pulley to change the direction and use the standard st 170 pump?
machine the block to take the older zetec escort/fiest pump?
any ideas people must have come accross this same problem?
Aug 13, 2008 | 03:30 PM
you can buy a pump from the US which pumps the direction you need, performance ford have one on their project KA zetec
Aug 13, 2008 | 04:07 PM
any more info or where from? sounds like the best option to me
Aug 13, 2008 | 04:40 PM
Quote:
Originally Posted by
Windle
Fit electric pump?
or you could just run the standard pump with a simple pulley,thats all i do and mine is a st170 turbo in a mk3 fiesta
Aug 13, 2008 | 04:55 PM
crazycage
any pics of how you have the belts routed,as im just doing a black top into a mk4 on carbs for a mate
Aug 13, 2008 | 05:05 PM
749steve
yeah no probs .this any good to you??
Aug 13, 2008 | 05:17 PM
looks well, what alternator mounting bracket are you using there just the standard fiesta turbo one?
Aug 13, 2008 | 05:52 PM
Raceline do an idler pulley to solve this problem
Aug 13, 2008 | 06:05 PM
Windle
yes a standard cvh one
Aug 13, 2008 | 07:17 PM
A little off topic , but does the pump of the silvertop go the right way'? as i'm planning on doing a zvh-->zetec conversion with a silvertop engine
Aug 13, 2008 | 07:48 PM
silver top if you use an escort/fiesta item i belive its fine. mondeo runs the wrong way round.
Aug 13, 2008 | 10:43 PM
what bracket is that? and what belt did you use?
cheers
Aug 14, 2008 | 08:08 AM
looks like a custom bracket bolted to the power steering/air con old st170 mount plate.
Aug 14, 2008 | 09:21 AM
if i remember right it's the wheel out of an alternator on a on a custom bracket but sure gary will put me right
Aug 14, 2008 | 06:16 PM
project rs
it basically just a bit of angle iron with 4 8.5mm holes and a slot with the rear auxiliary belt pulley off a focus/mondeo on it and a 1150mm belt and the cvh alternator with the zetec wheel on it and cvh bracket
robnock
21
May 13, 2019 05:29 PM
cameron2
Aug 25, 2015 07:18 AM
Chopshop85
Aug 17, 2015 06:38 PM
turbobill
Aug 9, 2015 05:21 PM
turbobill
Aug 1, 2015 08:55 PM
altarnator ,
black ,
blacktop ,
bracket ,
fiesta ,
fit ,
ka ,
pump ,
rs ,
rs1800 ,
top ,
turbo ,
water ,
waterpump ,
zetec
