what's a 2.1 zetec turbo worth?
Engine Machinist
as above? i've not got one for sale, but might be getting my hands on one soon and i want to make sure i'm not paying over the top for it
its not been run yet and uses forged 2.0 xe pistons. apparently it should do nearly 300bhp.
cheers
cheers
The XE pistons are from the N/A engines,
the LET pistons are from the turbo engines
in the ZVH I am sure they use the LET pistons not the XE ones due to the C/R. I would check which pistons have been installed. The XE's might have been skimmed but that will weaken them.
Do you have any more details about the engine?
what rods are they any head work done
Well, a standard zetec engine with LET pistons and uprated valve springs WILL do 300bhp, with the right turbo. I think you'd get det problems though with XE pistons at the same power level on pump fuel.
JoeyBoyden
Jan 4, 2024 02:36 PM
