Need Help.....20bhp resistor?!?!?!?!?!?!?!?!
Old Feb 9, 2004 | 04:43 AM
Default Need Help.....20bhp resistor?!?!?!?!?!?!?!?!
i got this thing of ebay for a 5ver that sposidly gives ya 20bhp lol
it looks like a resistor. that connects to ya coolant temperatur sensor.
This is exactly what the instruction guide says...
Locate the IAT sensor on your air intake tubing or in the airintake manifold. (if you do not have the IAT sensor, locate the plug on the coolant temperature sensor).
remove the plug and insert the resistor into the slots on the sensor.
wrap up the sensor with electrical tape (the sensor is not plugged back in)
start up your car and take for a spin. you will be able to feel the difference immediatly..
questions....
1. would this work
2. how the fuck does it work o n ya coolant temp sensor
3. would it have been easier to put a 5ver in the toilet and flush
any help would be helpful....
thanks
dave
Old Feb 9, 2004 | 06:28 AM
nthorpey's Avatar
nthorpey
no. 3 is prob most true
I'm pretty sure it makes th ecu think th eengine is cooler than it really is so that it will add more fuel making the mixture richer and therefore in theory of the boyracer making the car faster
Old Feb 9, 2004 | 06:47 AM
alan rainbow's Avatar
alan rainbow
put it in the ive been cond bin by telling the ecu it is colder than it is will amount to all sorts of problems
over fueling
bore wash
use alot of petrol
even det and blown engine
Old Feb 9, 2004 | 08:53 PM
richm's Avatar
richm
definitely option 3
Old Feb 10, 2004 | 01:31 AM
well this doesnt soung good does it? lol.. whats the worst that can happen?
Old Feb 10, 2004 | 01:37 AM
Stu @ M Developments's Avatar
PassionFords Creator
Dave, believe me, its bollox Wankers
What its doing is telling the ecu that the engine is slightly cooler than it really is whick in turn ups the injector duration somewhat.
On 90% of modern cars this is usefull as they are mapped to run 1 or 2 lambda points on the lean side for emissions and economy. However, when your engine really IS very hot and the ecu needs to retard the timing to stop detonation, it wont as that resistor has put a delay in the system
Also,
Give her a try at starting and running cold without teh coolant sensor plugged in to enrich her for you
Wankers mate....
Old Feb 10, 2004 | 01:40 AM
thanks stu... i was accross the way from your shop earlier at the clifford place... damn there expensive...
what would you recoment for my car?? what could you do to my car to get more power?
Old Feb 10, 2004 | 01:44 AM
Not cheap my brother in law is he? lol
Not sure to be honest as although i can see it, im not sure whats powering it
Old Feb 10, 2004 | 11:57 AM
1.6 mfi ... Do you do welding at your place or is it all engines.... i have a 4 janspeed branch zorst manifold for a xr2 to go on my car but i dont think its long enough...
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
beller
Sep 21, 2015 04:13 AM
Dr. Ickxs
Sep 15, 2015 10:15 PM
hydro st170
Ford Focus ST
Aug 28, 2015 01:26 PM
Martin-Hadland
90
Oct 26, 2008 09:17 AM
