5 injector ore cold start valve
Many people buy 5 injector. My question is, why dont they use the cold start valve for this option? You often only need extra fuelling at full throttle. Its simple to connect a electric source to the cold sart valve.
Br Butchi
Br Butchi
you can use the cold start valve. Most people buy thr mf2 system from erl. The 5th injecter system can be used for water injedction aswell and can be programmed to work at different rev ranges. Also you can use a larger injecter if you need to. A friend of mine uses the mf2 unit and mad 267 bhp still using the old mfi system with a 2.1 zvh.
The Enigma
13
Aug 20, 2015 09:38 PM
Archiejay
Aug 12, 2015 12:07 PM
Zoggon
Aug 10, 2015 10:39 AM
Red_bull
Aug 9, 2015 08:34 AM
