fiesta cuts out... not vss, any ideas?
Old Aug 6, 2008 | 10:27 PM
ScORTED's Avatar
ScORTED
Project Money Pit
Default fiesta cuts out... not vss, any ideas?
my car cuts out... i tohught it was the vss but its not
if i leave the car idling it will idle indefinately
if i go for a drive it will cut out when i brake to a low road speed (hence me thinking it was the vss)
if i unplug the tps the car stalls as it should, if i unplug the maf sod all happens
also if i rev it up then close the throttle while standing still it stalls
i'm thinknig i should try another tps, but not sure thats the fault
Old Aug 7, 2008 | 07:08 AM
I would look at the PCV valve and pipework to that first, as it sounds as though it is super lean around idle/low speed, very common problem on some.
Old Aug 7, 2008 | 07:12 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
It's not supposed to stall if you unplug the TPS.
Old Aug 10, 2008 | 04:00 PM
Robi81's Avatar
Robi81
At what RPM it stalls...
What is the lowest rpm that the engine is working on? If it cant hold 800-900 RPM then the camshaft is getting worse...
But if it surges ~500 RPM then you should adjust IDLE screw to 900 RPM with the IAC valve plugged...
Old Aug 10, 2008 | 05:19 PM
ScORTED's Avatar
ScORTED
Project Money Pit
ood that you mention the camshafts.. its got stage 1 cams in it
Fordmad!
Sep 26, 2015 05:24 PM
Rsmat
63
Sep 25, 2015 12:11 PM
Ben26
Sep 1, 2015 06:29 AM
Ben26
Aug 27, 2015 08:56 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
