CR ZVH-> Zetec
Hej all,
Been thinking to convert my 2.0 zvh to full zetec but what about the Compression ratio.
What will putting a zetec 16v head on there in stead of a cvh 8v head do to the CR?
Currently running 8:1
Thanks
Thanks
Looking to get close to 300 bhp at the flywheel.
Thought of running standard head and cams.
Stage 3 t3 wich i have now or maybe a t34 later.
What pressure will i have to run to achieve this?
Gonna do it myself so have to get me a zetec head and i'll calculate it then.
Just thought to ask first so i know what work to expect.
But for the setup i want is 8.5:1 ok or should the pistons be skimmed some more preferably?
Thanks all so far.
Thanks all so far.
What pressure are you driving it.. i thought you were also driving a zvh or am i mistaken with someone else??
Thanks all so far.
Thanks all so far.
just wondering why are you going down this route? what sort of power is your car pushing out now? does it drive well? im only asking as im doing a zvh in my s2. As for your original question, may I recommend speaking to chris at powerconversions.co.uk he really knows his stuff on these engines
Hi Greg
my car was pushing out 230 bhp at 12 psi @ 5800 rpm on mfi.
It's on efi now and it's pushing 18 psi.
Problem is it can't rev beyond 6000 k and currently i'm having problems to even getting that.
As a result i'm having a shit powerband as the turbo kicks in at arroud 3500.
With a standard t3 it was much more driveable :P
Problem seems te be in the head/cam/lifters or a combination.
For the same monney to get that sorted i can get it full zetec and certainly get more revs.
I'm not from England so'i'll have to sort it out myself i guess..
A ZVH can be a nice drive and pulls like mad with great torque but doesn't rev verry well most of the time
Hej,
sean
I was running my ZVH 2.0 at Ford Fair and kept running into the rev limit which is (7500). They do rev, you just have to get the balance of componants right, cam, cam timing, turbo, mapped right.
S.
S.
with the right head and cam your zvh will rev and i mean something like a stage three head is no good, just about flows enough for a 1600 start with a newman P4 cam solid lifters and single valve springs.. my old zvh peak power was around 6300 but now i know this was down to the very heavy valve train, car is currently in bits soon you will be able to see how far a zvh can rev.
sean
sean
I know they can rev but you have to put in some real money.
That's not an option for me so i can go 16v easier and cheaper.
I'm verry interseted in how your new egine will go .
Hej Pa Sjo, that's what i thought but i've tried about everything from spark advance to fuel to dwell settings but it doesn't seem to get better then 6k :S
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
