VIBRATION
Old Aug 2, 2008 | 10:19 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Smile VIBRATION
Hi anyone got any ideas why my s2 has a slight vibration through the steering wheel at 60mph?ive had a new rack,powerflex bush kit,wheel bearing and had the wheels balanced,but the vibration is still there at 60mph any faster it goes.
Thanks in advance for any advice.
Old Aug 2, 2008 | 10:47 PM
JesseT's Avatar
JesseT
Have you actually tried another set of tires?
Old Aug 2, 2008 | 10:56 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Yea tried sum brand new wheels.
Old Aug 3, 2008 | 10:07 AM
Daveysaff's Avatar
Daveysaff
Skint Passionford User
Did you use new tie rod ends when you changed the rack, and have you fitted new TCA's?
Old Aug 3, 2008 | 03:52 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
snap mine does this, has wheels balanced new suspension polys all round, m thinkin it my steerin rack?
Old Aug 3, 2008 | 09:13 PM
RSMK4TURBO's Avatar
RSMK4TURBO
Just a new rack will ask my mechanic if anything else,could drive shafts course this problem?
Old Aug 3, 2008 | 09:46 PM
grayzo's Avatar
grayzo
grayzo
warped discs maybe
Old Aug 4, 2008 | 10:46 AM
gee1599's Avatar
gee1599
i had the same problem and it was a bent offside drive shaft im not saying thats your problem but i would check both shafts out
Old Aug 4, 2008 | 12:26 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Just drive faster
Old Aug 5, 2008 | 12:08 AM
Grandad racer's Avatar
Grandad racer
i had this problem, spent loads of money, changed eveything, turned out it was a loose rear wheel bearing, you would never think that would affect the front end , but it does, hope this helps!!
pabloXR
Sep 21, 2015 12:42 PM
Fudgey
Sep 17, 2015 01:06 PM
talon1
Sep 15, 2015 10:27 AM
gingeRS
Sep 4, 2015 06:29 PM
jason_nike
Aug 31, 2015 10:15 PM
