e46 m3 VANOS
Old Aug 1, 2008 | 10:49 AM
cheeky dog's Avatar
cheeky dog
Default e46 m3 VANOS
do they suffer from vanos problems like the e39 m5 pre 2000 models?
if so what year do i avoid?
what is vanos to start with?
TANX
Old Aug 1, 2008 | 11:01 AM
rog's Avatar
rog
There are a few people on here with M3's mate but also maybe try here too.
http://www.m3forum.net/m3forum/forumdisplay.php?f=9
Old Aug 1, 2008 | 11:07 AM
cheeky dog's Avatar
cheeky dog
i seriously dont really want to register a bmw forum..... they're a bunch of p**ks!
Old Aug 2, 2008 | 08:33 PM
Steven_RW's Avatar
Steven_RW
The m3 forums weren't so bad imo - the evo forum has some serious idiots on it. As soon as u mention going fast they all gang up and try and take the piss.
The e46 m3 does not suffer from vanos issues. (not that I have heard of)
(ps I have an e46 and use it hard as a daily runner)
RW
Old Aug 2, 2008 | 08:37 PM
C4llyT's Avatar
C4llyT
Never heard of any E46 issues, so rare at worst.
But then again I'm a prick so you won't believe me...
Old Aug 2, 2008 | 08:48 PM
JjCoDeX75's Avatar
JjCoDeX75
What an enlightened view! I am sure you will be a valuable addition to the M3 owners club.
JJ
Old Aug 2, 2008 | 08:51 PM
Doby's Avatar
Doby
VANOS is a combined hydraulic and mechanical camshaft control device managed by the car's DME engine management system.
The VANOS system is based on an adjustment mechanism that can modify the position of the intake camshaft versus the crankshaft. Double-VANOS adds an adjustment of the intake and outlet camshafts.
VANOS operates on the intake camshaft in accordance with engine speed and accelerator pedal position. At the lower end of the engine-speed scale, the intake valves are opened later, which improves idling quality and smoothness. At moderate engine speeds, the intake valves open much earlier, which boosts torque and permits exhaust gas re-circulation inside the combustion chambers, reducing fuel consumptionn and exhaust emissions. Finally, at high engine speeds, intake valve opening is once again delayed, so that full power can be developed.
VANOS significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. The latest version of VANOS is double-VANOS, used in the new M3.
VANOS was first introduced in 1992 on the BMW M50 engine used in the 5 Series.
Here's how it works:
In overhead cam engines, the cams are connected to the crankshaft by either a belt or chain and gears. In BMW VANOS motors there is a chain and some sprockets.
The crankshaft drives a sprocket on the exhaust cam, and the exhaust cam sprocket is bolted to the exhaust cam. A second set of teeth moves a second chain that goes across to the intake cam. The big sprocket on the intake cam is not bolted to the cam, for it has a big hole in the middle. Inside the hole is a helical set of teeth. On the end of the cam is a gear that is also helical on the outside, but it's too small to connect to the teeth on the inside of the big sprocket. There is a little cup of metal with helical teeth to match the cam on the inside and to match the sprocket on the outside. The V (Variable) in VANOS is due to the helical nature of the teeth. The cup gear is moved by a hydraulic mechanism that works on oil pressure controlled by the DME.
At idle, the cam timing is retarded. Just off idle, the DME energizes a solenoid which allows oil pressure to move that cup gear to advance the cam 12.5 degrees at midrange, and then at about 5000 rpm, it allows it to come back to the original position. The greater advance causes better cylinder fill at mid rpms for better torque. The noise some people hear is the result of tolerances that make the sprocket wiggle a bit as the cup gear is moved in or out.
Double VANOS
Double-VANOS (double-variable camshaft control) significantly improves torque since valve timing on both the intake and outlet camshafts are adjusted to the power required from the engine as a function of gas pedal position and engine speed.
On most BMW engines that use a single VANOS, the timing of the intake cam is only changed at two distinct rpm points, while on the double-VANOS system, the timing of the intake and exhaust cams are continuously variable throughout the majority of the rpm range.
With double-VANOS, the opening period of the intake valves are extended by 12 degrees with an increase in valve lift by 0.9 mm.
Double-VANOS requires very high oil pressure in order to adjust the camshafts very quickly and accurately, ensuring better torque at low engine speeds and better power at high speeds. With the amount of un-burnt residual gases being reduced, engine idle is improved. Special engine management control maps for the warm-up phase help the catalytic converter reach operating temperature sooner.
Double-VANOS improves low rpm power, flattens the torque curve, and widens the powerband for a given set of camshafts. The double-VANOS engine has a 450 rpm lower torque peak and a 200 rpm higher horsepower peak than single-VANOS, and the torque curve is improved between 1500 - 3800 rpm. At the same time, the torque does not fall off as fast past the horsepower peak.
The advantage of double-VANOS is that the system controls the flow of hot exhaust gases into the intake manifold individually for all operating conditions. This is referred to as "internal" exhaust gas re-circulation, allowing very fine dosage of the amount of exhaust gas recycled.
While the engine is warming up, VANOS improves the fuel/air mixture and helps to quickly warm up the catalytic converter to its normal operating temperature. When the engine is idling, the system keeps idle speeds smooth and consistent thanks to the reduction of exhaust gas re-circulation to a minimum. Under part load, exhaust gas re-circulation is increased to a much higher level, allowing the engine to run on a wider opening angle of the throttle butterfly in the interest of greater fuel economy. Under full load, the system switches back to a low re-circulation volume providing the cylinders with as much oxygen as possible.
Old Aug 3, 2008 | 09:30 AM
AlexF's Avatar
AlexF
LOL nice copy and paste
but sadly bmw VANOS is only used with chain drive not belt drive as that article suggests!
Cheeky Dog,
What do you specifically want to know about VANOS? Is yours ratteling?
Alex
Old Aug 3, 2008 | 09:41 AM
Doby's Avatar
Doby
alex it clearly says bmw use chain!It was just saying how the cams were connected to the crank some cars belt others chain.
Old Aug 3, 2008 | 10:29 AM
AlexF's Avatar
AlexF
Your right - I miss read that, its not exactly clearly written when you start to decribe a specific system and and instantly start by stating the bleeding obvoius about generic systems LOL
But its still not correct.
Its more like 60 degrees (in total they are saying 12+15)\and the is no change in valve lift at all - that is the what the ValveTronic system achieves.
Internal EGR is achieved by not allowing all the exhaust gas to escape. The exh gas does not get into the manifold. If you consider M engines typically have individual TBs and so allowing EGR into the inlet manifold would cause a few issues.
Other than that its accurate enough
But its still probably not what Cheeky Dog is asking - as I suspect he's asking why his E46 M3 is rattleing!
They do suffer with VANOS rattle and its not a cheap fix - cira £1000 in parts alone!
Alex
Old Aug 3, 2008 | 11:00 AM
Doby's Avatar
Doby
PF is for learning and i found that interesting,even though it has a couple of errors you say and check his post he does actually ask what a vanos is.
as for the rattling no idea
Old Aug 3, 2008 | 11:23 AM
st3v3's Avatar
st3v3
big up to Phill for an informative post.
Old Aug 3, 2008 | 01:43 PM
AlexF's Avatar
AlexF
and not biting
Old Aug 3, 2008 | 02:20 PM
Paul Eggleton's Avatar
Paul Eggleton
I'm sure they'd welcome you with open arms with that attitude...........
Oranoco
41
Feb 11, 2016 01:28 PM
Oranoco
12
Oct 2, 2015 02:18 PM
Ebonycossie4x4
15
Sep 2, 2015 11:40 PM
Lee Reynolds
85
Aug 10, 2015 05:56 PM
COSSIE 1
Feb 22, 2007 07:34 PM
