turbo problem!!
Old Jul 29, 2008 | 08:13 PM
s1cab's Avatar
s1cab
Angry turbo problem!!
basically i've just finished putting my series 1 cab back together after respray. took it to paul hills at engine advantages to get set up and couldn't get the turbo to boost over 17psi and that was with the bleed valve removed. the system has no airleaks. the actuator opens at 13pounds which paul hills said was fine! timing is spot on. and its very very very very laggy !! its a t3 with 360tst and t34 compressor whell. turbo is brand new from turbo centre. im guessing theres proberbly something wrong with the wastegate? as its like its opening far too early or just not sealing properly. i've sent the turbo back to them today and they will get it tommorow! they said they've never had a problem with one of these turbos before, if anyone has used these before i would like to know thanx! so pissed as i was gonna see her reach over 300bhp garanteed by paul hills. suposed to have track action at ford fair this sunday so im very pissed!!! as you can all imagine!! but they promised me they will get it back to me friday.
why cant it just all go to plan !!
any ideas of what else it may be??
thanks for reading !
Old Jul 29, 2008 | 08:24 PM
JoeRS22's Avatar
JoeRS22
hey scab have you tried checking your flux capacitor??
Old Jul 29, 2008 | 08:25 PM
s1cab's Avatar
s1cab
ill put my flux capacitor up your arse !!
Old Jul 29, 2008 | 08:27 PM
JoeRS22's Avatar
JoeRS22
Default WOW!!!!
tell me more..........
Old Jul 29, 2008 | 08:29 PM
s1cab's Avatar
s1cab
Old Jul 29, 2008 | 08:32 PM
JoeRS22's Avatar
JoeRS22
the sooner u get the turbo back the sooner we can get it on and hopefully get 30psi! u coming to harpendon in the cos tm?
Old Jul 29, 2008 | 08:36 PM
s1cab's Avatar
s1cab
amen !!!
Old Jul 29, 2008 | 08:37 PM
s1cab's Avatar
s1cab
amen !!!
Old Jul 29, 2008 | 08:39 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Over 300bhp on what engine?
Old Jul 29, 2008 | 08:40 PM
JoeRS22's Avatar
JoeRS22
sweet! hopefully someone on here will have tried one of your turbos and give some feedback....?
Old Jul 29, 2008 | 08:42 PM
JoeRS22's Avatar
JoeRS22
steel bottom end and stage 5 head.
Old Jul 29, 2008 | 08:43 PM
s1cab's Avatar
s1cab
i bloody hope so!!!!
what an amazing pic!!
it reminds me of me dj'in !! looks a bit like me 2 !
i think i see you in the crowd....back row 3rd in from left with a big grin listening to ratpack !lol
Old Jul 29, 2008 | 08:45 PM
s1cab's Avatar
s1cab
1600 cvh
forged pistons,rods and crank.
was making 283 before tubula manifold, new turbo and bigger intercooler so no reason at all that it won't be over 300!
Old Jul 29, 2008 | 08:49 PM
s1cab's Avatar
s1cab
this is for you joe !!
Old Jul 29, 2008 | 08:50 PM
JoeRS22's Avatar
JoeRS22
Default bhp
1600 cvh
THATS STRONG POWER FOR A 1600....
Old Jul 29, 2008 | 08:54 PM
s1cab's Avatar
s1cab
only the best for my prescious !!
Old Jul 29, 2008 | 08:57 PM
JoeRS22's Avatar
JoeRS22
good luck getting an answer on here matey, let me know if they call u tm..
Old Jul 29, 2008 | 09:01 PM
s1cab's Avatar
s1cab
will do if they dont then this will happen !!
then this
then
Old Jul 31, 2008 | 08:35 PM
JoeRS22's Avatar
JoeRS22
1600 cvh
thas funny i herd it was 28.3 bhp
Old Jul 31, 2008 | 08:37 PM
s1cab's Avatar
s1cab
coming from the man that thought his cossie was blown up !! lol
and all it was, was the water pump bolts were loose !!!
Old Jul 31, 2008 | 08:42 PM
JoeRS22's Avatar
JoeRS22
Default SCAB
i dont know why u unbolted the turbo i fucking told u it was the actuator listen to uncle joey next time!!!
do you want a new dummy???
Old Jul 31, 2008 | 08:44 PM
s1cab's Avatar
s1cab
they found a small hairline crack in the housing sunshine!!
: boxer::b oxer:
Old Aug 2, 2008 | 10:34 PM
s1cab's Avatar
s1cab
got turbo back ! they have changed the compressor housing and wastegate/elbow! but still the same i'm only making 10psi why??? put new -34 actuator on aswell! no boost leaks. actuator has plenty of preload. any ideas any1???? im running out!!!
Old Aug 3, 2008 | 06:32 AM
s1cab's Avatar
s1cab
any one?????
Old Aug 3, 2008 | 10:04 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
have you tried disconnecting the actuator briefly?
if it won't go over 10psi then it's the turbo dead.
i just think you're not giving enough preload to the actuator though.
bleed valves aren't an accurate way of setting boost TBH.
Old Aug 3, 2008 | 10:20 AM
cossie604's Avatar
cossie604
Its not just sommot daft like a wanky dump valve opening up on you?
Old Aug 3, 2008 | 10:24 AM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
lol
Old Aug 3, 2008 | 04:35 PM
s1cab's Avatar
s1cab
brand new turbo its the second one. allready sent one back to them and they sent me this one. there is plenty off preload for sure! took bleed valve off now and should still see a bar but just not getting it?!
Old Aug 3, 2008 | 04:36 PM
s1cab's Avatar
s1cab
don't have dump valve.
Old Aug 5, 2008 | 04:14 PM
s1cab's Avatar
s1cab
problem solved was dodgy intercooler!!
Matt Baxter
Sep 16, 2015 08:30 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
druidgetafix
Aug 15, 2015 10:22 AM
