Engine guru's PLEASE HELP...........
Old Jul 29, 2008 | 05:37 PM
bigpower's Avatar
bigpower
Default Engine guru's PLEASE HELP...........
My mate has a 4x4 H Plate Saff and is is real need of some help......
He's had the engine rebuilt, stage 3, breather etc etc
His cars is smoking but symptoms to me are strange...
If you rev it when stationary it smokes
if you start it...NO smoke
If you drive it underload... NO smoke
If you let over run...NO smoke
If you re-apply throttle... IT Smokes
The car is collecting oil in the plenum and collecting around No4 piston!!??
The car also breathes fairly heavey.
The car seems to drink fuel.
The smoke is more bluey than black
Its been checked for mapping.... FINE
Its had a brand new Turbo.
He's checked compression and ALL OK
Leak tested and ALL OK
He's stumped!?? and i cant help him, so i thought i'd ask for him, due to him not been into the t'internet
Any help appreciated
Old Jul 29, 2008 | 07:12 PM
bigpower's Avatar
bigpower
no one?
Old Jul 29, 2008 | 09:22 PM
LHD220Turbo's Avatar
LHD220Turbo
if its cold on first start up; does it puff out a bit of blue smoke?
did it have new guides or valve stem seals?
Old Jul 29, 2008 | 09:25 PM
bigpower's Avatar
bigpower
Its doesnt puff anything when cold he says?
As im a bufty i helped him mint it the other week and the exhaust ( which i polished!! ) sutted up very quickly, and i thought fuel, but he says its been checked and is fine?? A VW mechanic looked and he seemed to think it had fuel in th eoil, but i couldnt tell TBH?
Old Jul 29, 2008 | 09:26 PM
Mark Shead's Avatar
Mark Shead
You say rebiuld, What parts were used and what parts replaced.
Mark
bigpower's Avatar
bigpower
Its had new pistons,rings,valve guides,stem seals, tappets, cams, cranks etc etc
Old Jul 29, 2008 | 09:30 PM
Mark Shead's Avatar
Mark Shead
Take the inlet manifold off and look at the inlet ports around the valve giude, I have seen some engines that have had new giudes and its been leaking oil down the outside of the giudes.
Mark
Old Jul 29, 2008 | 09:32 PM
bigpower's Avatar
bigpower
would that collect in the plenum and cause the same symtoms under the conditions ive said?
He told me that the guides were oversized?
But what about the excessive fuel?
Old Jul 29, 2008 | 09:34 PM
bigpower's Avatar
bigpower
wouldnt that show on the leak test??
My mate works at sainsburys, so all he knows is VEG PMSL and im not that mech minded ( just basics!! )
Old Jul 29, 2008 | 09:35 PM
Mark Shead's Avatar
Mark Shead
Who checked the fueling and how,
What were the bore clearances,
The giudes could have damaged the head/giude as it went in, I have seen this often.
Mark
Old Jul 29, 2008 | 09:37 PM
Mark Shead's Avatar
Mark Shead
A leak down test only shows what sealing and how much, it cant show giude problems.
Mark
Old Jul 29, 2008 | 09:40 PM
bigpower's Avatar
bigpower
Mark you have PM
Old Aug 2, 2008 | 07:35 AM
nobbie_b's Avatar
nobbie_b
def worth checking the valve guides get someone to go over the head propely stem seals one of them may not be seated rite could be a mix of both but sounds very weired
Old Aug 2, 2008 | 09:13 PM
costina's Avatar
costina
Live long and prosper!!
Oil in the plenum is usually down to turbo.I,ve had this on mine found the turbo was leaking from the compressor into cooler and getting into plenum
Only way was to clean everything big job but worth it
You say its collecting around no 4 at the top? looking in around the spark plug hole or inside the bore? if the first around the hole its the cover gasket failed if the bore seems like the guides as Mark has suggested
Remember any oil in the combustion cycle will cause det so be carefull
Let us all know how u get on
Paul
Old Aug 4, 2008 | 07:28 AM
bigpower's Avatar
bigpower
will do, wont be seeing him till later in week, but last tim ei spoke he was throwing towel in!
mgtkr1
107
Dec 6, 2016 04:23 PM
hopper350
Sep 4, 2015 12:53 AM
